Drivers memory seat issue
Old Jun 26, 2018 | 10:09 PM
Metoleous's Avatar
Metoleous
7th Gear
Default Drivers memory seat issue
Hi I'd like to introduce myself. My name is Paul. I had this under C5 Tech but got absolutely no responses, I thought maybe under general it would get more hits. So the problem I'm having with my 1999 driver side seat is the bolster controls do the opposite of what they should when pressed. When you pull up on the switch, it goes down. Push down, it goes up. Forward is back and back is forward. When using the memory function the seat Drives completely forward and down. the mirrors work fine. I turned off the memory, so I don't so I don't know if the steering column goes in or out. Although you can adjust it manually. I've had the seat out and I have ohm checked all the wiring. Thanks... Oh yeah and I have all the maintenance manuals. Although my pitbull did chew up a few pages
Old Jun 28, 2018 | 05:17 PM
Metoleous's Avatar
Metoleous
7th Gear
It actually it worked fine when I bought the car. it only started screwing up after I put the driver seat back in with new seat covers. I took it all apart again and ohmed the wires. They are all good. I have the complete manuals although Bob my pitbull decided to chew a few pages.....
Old Jul 2, 2018 | 01:27 AM
Metoleous's Avatar
Metoleous
7th Gear
IllI check, thank you
To Drivers memory seat issue
