Painted Interior Inlay And Need Help
Old Jun 27, 2018 | 08:52 AM
Whorevette's Avatar
Whorevette
Cruising
Default Painted Interior Inlay And Need Help
So the other day I went on a search for a red sharpie paint marker as I have researched they are the best for painting the Corvette inlays inside and outside the car. I couldn't find the actual sharpie brand in any of the local stores so I got another brand of paint marker. Well that was a mistake as it made the entire project difficult and a little messy. I got it finished but when direct sunlight hits the dash the area around it now has a red tint to it from the marker parts that I had whipped away. I tried using brake cleaner as I had a can handy but it didn't work. My question is how can I remove the leftover paint without hurting the color of my dash or hurting it in any way?
Old Jun 27, 2018 | 11:16 AM
Velocity_Vette's Avatar
Velocity_Vette
I wouldn't use brake cleaner on interior or painted material. It is very abrasive and will easily damage those sorts of items. I would use something like Green Stuff, WD-40 (yes, WD-40), or spray sun screen, whichever of those you have handy. Spray directly onto the interior components and immediately wipe across. Do not apply lots of pressure or scrub excessively. Then detail the spot with a good interior cleaning product.
Yeah future reference in terms of brand markers nothing is better than the actual Sharpie brand. There's reasons why they're often more expensive. You'll notice ex: with black Sharpies they tend to be the only markers that are "true" black. Other brand black markers typically take on a purplish hue and they have a tendency to "soak" whatever it is they're marking. Other colors also take on similar "soaking" property when marking things. Most hardcore artists that do "Sharpie art" will only use true Sharpies.
Old Jun 27, 2018 | 11:43 AM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
Maybe try a magic eraser?
Old Jun 28, 2018 | 02:35 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I've done many corrections with WD-40. At least, I don't believe this will hurt your paint/interior even if it doesn't clean up the markings left from the excess paint like some other things . Cheap fix if it does.
Also, not only is brake cleaner not good for this as Velocity_Vette stated, but almost all brake cleaners use chemicals that are very flammable and they can make you ill or also be toxic if used in closed environments such as the cockpit of your Corvette.
Best wishes with your clean up.
Old Jun 28, 2018 | 02:56 PM
Smoken1's Avatar
Smoken1
As for flammable yes, but as for making you ill or be toxic in a closed environment, Naa you will be fine
Old Jun 28, 2018 | 03:08 PM
Whorevette's Avatar
Whorevette
Cruising
I'll just get a little high no biggie!!!
Old Jun 28, 2018 | 03:14 PM
Smoken1's Avatar
Smoken1
Old Jun 29, 2018 | 01:01 AM
Not sure if it will take take the unwanted paint off or not, but maybe try a little rubbing alcohol on a rag and see if it does the trick.
To Painted Interior Inlay And Need Help
