Powerbond harmonic balancer
Old Jun 29, 2018 | 11:18 PM
wildazme's Avatar
wildazme
Default Powerbond harmonic balancer
Hi I recently noticed my pulley was wobbling. I'm going to have it replaced. I purchased the powerbond pulley stock one I believe Summit Racing has it on sale for $73. I just want to make sure this is the correct one that I should be replacing it with. I also bought another Factory pulley bolt to replace it with. And I also bought a crank shaft seal. Is this all I should need to replace the crankshaft pulley with. Thanks for your time.
Old Jun 29, 2018 | 11:25 PM
Arvalo's Avatar
Arvalo
From what i understand that HB should be correct, however most recommend not using the OEM bolt but rather the reusable ARP bolt.
Old Jun 30, 2018 | 10:48 AM
momo20's Avatar
momo20
the stock bolt is a TTY bolt so one time use only ..would never ever use it twice...you can use a new OEM TTY bolt with zero issues provided you follow the correct torque seq. the ARP bolt is nice as well and really not that pricey when you can re use it
Old Jun 30, 2018 | 01:14 PM
envisi0n91's Avatar
envisi0n91
I got the powerbond you speak of about 2 months ago, seems to be working well for me. Make sure you check pulleys and belts and replace while you're there.
To Powerbond harmonic balancer
