Door Panel Fix
How can I secure it?
I probably have a dozen adhesives to choose from, but I want to avoid putting a hole in the door to insert and spread it if I can.
Any other thoughts or similar experiences?
I could always replace the entire panel. But I have odd sentiments about not parting with original pieces of the car if I can avoid it.
https://www.corvetteforum.com/forums...up-how-to.html
Another method is to use a set of leather armrests as shown in this link. The technique is to carefully make a thin cut in the door panel ahead of the delaminated area (don't worry - the arm rests will cover the slice when finished), then open the cut enough to spread or spray an adhesive, such as contact cement, into the area that's delaminating and press the two surfaces back together until a bond has formed. Then use the leather armrest pad to cover the slice in the door panel. This method works well and the new arm rests are a plus. This method might also be a little less risky because any damage to the panel is covered up. In the first method, the drill bit could penetrate too far and put a hole in the vinyl panel that would be hard to hide later.
https://www.corvettemods.com/C5-Corv...saAiZ4EALw_wcB
Either way, the panels can be repaired for a modest cost. Your choice!
