2 piece plenum cover install
Old Jul 18, 2018 | 04:44 PM
rayz1951's Avatar
rayz1951
Default 2 piece plenum cover install
I bought a 2 piece faux carbon fiber plenum cover from vette works but they didn't send any install instructions with it. Can someone tell me how to attach it to the oem plenum?
Ray Z
Old Jul 18, 2018 | 04:46 PM
Keev1414's Avatar
Keev1414
2017 C5 of the Year Finalist
Black general purpose permantex.
4.00 to 5.00 a tube at walmart.
Old Jul 18, 2018 | 08:16 PM
Honestly, it depends on how the two piece plenum cover is designed. I have a two piece cover on mine and it attaches by mounting over the studs for the fuel rails and then uses a nut to secure the cover to the fuel rail studs. Makes for a very secure attachment. Others I have seen use double sided tape to attach to the intake manifold - not sure I would want that as it would make it more difficult to remove should you ever need to do so. Some pictures of your plenum cover, both from the top and bottom sides would help.
To 2 piece plenum cover install
