Perf Axle in Vin
Old Aug 1, 2018 | 02:44 PM
timstl's Avatar
timstl
Default Perf Axle in Vin
Soon as my 96 CE sells looking at a couple of 97-99's, is there a way to tell in the VIN (or other way) to see if car has Perf Axle option?
Old Aug 1, 2018 | 02:59 PM
GCG's Avatar
GCG
Check to see if RPO Code G92 (3.15 axle ratio) is listed in the glove compartment sticker.
Old Aug 1, 2018 | 03:03 PM
grantv's Avatar
grantv
Keeping in mind...
-stick cars get 3.42
-stuck on auto? Someone previously may have been also, and swapped rears for a 3.42 set
Old Aug 1, 2018 | 05:35 PM
Fcar 98's Avatar
Fcar 98
My 98 has 315 written on the cover of the axel cover
Old Aug 1, 2018 | 07:38 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Test drive the car and cruise at 60mph. Assuming it has the standard 275/40/18 tires (26.7" diameter), the following differential gears will give you the engine rpms shown:
2.73 differential gears will pull 1445rpm at 60mph
3.15 differential gears will pull 1668rpm at 60mph
3.42 differential gears will pull 1810rpm at 60mph (Assuming you were lucky and someone had swapped to these gears).
Old Aug 1, 2018 | 11:30 PM
No way to tell by the VIN, unless you take the VIN to a dealer and have them run a report with all the option codes listed. Just check the RPO listing for the G92 code.
To Perf Axle in Vin
