DRL to LED
Old Aug 1, 2018 | 08:01 PM
rnd2itranch's Avatar
rnd2itranch
3rd Gear
Default DRL to LED
Want to replace front drl light with LED. Auto Zone tells me 3157A is the correct bulb. For that amount of $ want to be sure it is correct. Package states: also fits compatible 3457/4157. Thanks.
Old Aug 1, 2018 | 08:09 PM
1stC599's Avatar
1stC599
You could have Google autozone and the part number yourself and used fit my car, instead ask someone else, but yes they fit. Welcome.
Old Aug 1, 2018 | 10:33 PM
Tsumi's Avatar
Tsumi
It may or may not necessarily fit. Tall LED bulbs will not fit in the housing. It will not take anything much taller than the stock bulb.
Additionally, you will want to check whether or not your housing has cracked. If it has, rain and water can get inside and kill your LED bulb.
Old Aug 2, 2018 | 05:52 AM
jdmvette's Avatar
jdmvette
Night Owl for life
screw vatozone, especially if they're expensive
get these from ebay
https://www.ebay.com/itm/2x-120-SMD-...back.TRS0.TSS0
Old Aug 2, 2018 | 07:20 AM
runner140*'s Avatar
runner140*
Your answer nailed it.
Old Aug 2, 2018 | 11:34 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
get these from ebay
Even lower priced options, sorted by price:
https://www.ebay.com/sch/i.html?_from=R40&_nkw=3157+switchback&_s acat=0&LH_BIN=1&_sop=15
Look at length dimensions as others mentioned, and select accordingly. Anyone know the length of the stock bulbs to help in the selection of bulbs?
Old Aug 2, 2018 | 11:56 AM
rnd2itranch
3rd Gear
Have replaced housing on both sides as previous bulbs had damaged them. Thank you for the info.
Old Aug 2, 2018 | 12:17 PM
jrprich's Avatar
jrprich
Yep, been there, done that. A lot of LED bulbs are longer than the OEM and will not fit the housing ;^(
Measure twice, order once ;^) Or buy from Amazon so you can easily return the too long bulbs........
Old Aug 2, 2018 | 12:43 PM
rnd2itranch
3rd Gear
Thank you all who responded politely and helpfully to my post. I called Sylvania this am. They confirm I have the correct bulbs FYI 3157A.
I'm a 70 year old female & enjoy doing small jobs on my '03. Great feeling of accomplishment in replacing the housing didn't want to mess them up w/wrong bulb. The forum has helped me on every project.
Again, thank you all for the forum!
Old Aug 2, 2018 | 12:54 PM
1KLRTOY's Avatar
1KLRTOY
Check Radioflyer all his stuff works and fits the housings
Old Aug 2, 2018 | 07:48 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Sounds like your DRLs will be both brighter and cooler! That's a win-win.
To DRL to LED
