C5 brakes are pretty good.
Today I was cruising down a country road about 60 when an oncoming truck started to turn into a driveway right in front of me. I figured this was it. I jammed on the brakes as hard as I could and thought about should I go left. He panicked and stopped with half his truck in both lanes and then decided not to turn. The ABS worked great since I still had control, but there wasn't any place to go but the ditch. At the last second he straighten into his lane and I went right as I was almost stopped.. As I passed him he gave me a scared grin . I am convinced if I had been driving my truck I would have hit him or had to take the ditch.
Glad everything turned out good for you and no damage was done to your car or anyone was hurt. That is how abs is suppose to work. Brake hard and still able to steer. My original pads and rotors were terrible. I changed out the whole system after the first year of ownership.
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Agreed, the brakes are really good for street use, and the car being lightweight helps A LOT.
A C5 Corvette weighs about 500 pounds less that a bare bones 4 cylinder Mustang and about 1000 pounds less than a fully optioned Hellcat.
The brakes on a C5 are perfectly good in all but the most demanding applications. Sure...they look a little goofy through the wheels (especially the rears), but having taken my Vette down a couple of mountain twisties...I can tell you that the stock brakes are decent for street applications.
I would venture to say that with some good pads and better rotors, the brakes would be up to almost anything you threw at 'em outside extreme racing...but they still look pretty goofy.
Actually, thank your TIRES.
Brakes were the first thing I did when I bought my car. Pads, SS lines and fresh ATE fluid. I never mess around with brakes, and I over-maintain and replace them. Of everything on your car, brakes and tires are the two things you never cheap out on.
Received 19,300 Likes
'20-'21-'22-'23-'24
Glad you were able to avoid the guy. Yes, the brakes are good and quick reactions help.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Great you were able to avoid the truck and fortunate he moved back into his lane.
speed
In Germany I regularly drove at 150 mph and one time had to stop real fast as another car pulled out in front of me, the car slowed down real fast, the German that was chasing me went across the field to stop from hitting me. I found that when you hit 160 mph the front end tends to lift. I had a 2003 Z06 then.
