Pressure wash question
Old Aug 8, 2018 | 01:54 AM
Big Jay E's Avatar
Big Jay E
Default Pressure wash question
Going to clean my engine. Will Simple Green everything then pressure wash it. I remember reading on here sometime ago that there is one area that you should not hit with the pressure washer. Anyone know?
Old Aug 8, 2018 | 06:14 AM
Arvalo's Avatar
Arvalo
If nothing else I’d recommend putting a plastic bag over the alternator.
never used a pressure washer on the engine myself, usually just a normal water hose.
Old Aug 8, 2018 | 09:06 AM
pjdbm's Avatar
pjdbm
Lots of areas you shouldn't hit....
The intake is not watertight, fuse box area, alternator.
I use very rarely, just a garden hose mist and a mild degreaser. Pressure washer maybe the under body and that's it.
Old Aug 8, 2018 | 09:13 AM
I would not use a pressure washer on the engine. If you need to use water, a garden hose with a gentle spray should work just fine. Others may have used a pressure washer and had no problems, but I prefer to be cautious.
Old Aug 8, 2018 | 10:16 AM
GCG's Avatar
GCG
Pressure washing the engine is a
Old Aug 8, 2018 | 03:54 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I know there are many who suggest you can pressure wash the entire engine and engine bay, but there are too many potential pitfalls for me. It's almost like the battery question of whether the AGM battery is needed. Many people have used regular batteries for years with no problems but others have had the battery leak that damaged wire harnesses, the Throttle Actuator Control or Power-train Control Modules, or the vacuum lines for the A/C. To me, many of these same areas (especially the TAC or PCM) can be affected by high pressure water spray.
Hopefully all goes well for you if you do pressure wash, and it does make your engine and bay look good.
Old Aug 8, 2018 | 06:23 PM
CQRT's Avatar
CQRT
Simple green half strength on a warm engine- avoid the belts . . .use a soft bristle brush to loosen caked on stuff- bag the alternator and the fuse block... use a regular garden sprayer to rinse things off and let it dry for awhile without starting until things are generally dry - - use a towel to mop up standing water. If you want to go nuts with a high pressure sprayer underneath the car and in the wheel wells and barrels of the wheel fine- but suggest you not use high pressure on the engine.
While you're at it- it might be a good time to direct the pressure from the hose from inside the engine compartment forward on the radiator to try and blow out bugs and crud.
I also have used tire foam on the plastic parts-- avoid the belts on the front of the engine-- and then use a damp wash cloth to even things out.
Good luck-
Old Aug 9, 2018 | 12:00 AM
Big Jay E's Avatar
Big Jay E
Thanks guys. Guess I'll pass on the pressure washer.
Old Aug 9, 2018 | 01:52 AM
Loby 1's Avatar
Loby 1
Good decision IMHO.
Old Aug 9, 2018 | 07:03 AM
runner140*'s Avatar
runner140*
Stick with Simple Green and a roll of paper towels....ONLY.
Old Aug 9, 2018 | 07:46 AM
Spaceme1117's Avatar
Spaceme1117
I use full strength Simple Green in the engine bay several times along with pressure washing. I use low pressure around any electrical components and stay away from the alternator. Any areas with caked on dirt or grease, I will go with high pressure but sparingly. I have done this at least 3 times on my Z06 and have never had any problems. I will wipe down as much excess water as I can then go for a drive to evaporate any pooled water.
Old Aug 9, 2018 | 07:53 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just a thought.....if you use something like Simple Green, and a soft bristle brush, followed by a rinse with the garden hose, every once in a while, you WON'T have to deal with "caked on grease", that requires "high pressure washing" to clean it off.....
Old Aug 9, 2018 | 07:57 AM
SG Lou's Avatar
SG Lou
Originally Posted by 8VETTE7
If you don't mind the electrical problems you are going to have after pressure washing under the hood, then by all means do so.
Old Aug 9, 2018 | 09:05 AM
Spaceme1117
I completely agree. I purchased my Z06 only a little over a year ago and so was not the original owner. The original owner was not a meticulous as I would have been in keeping the engine clean (he was very meticulous on mechanical maintenance thankfully).
I have had several cars over the years and have used Simple Green and a pressure washer and not had any problems. But, you need to use good judgement on where you can hit with high pressure. Areas like the side of the block, the oil pan area, etc. are quite safe. Electronic components, wiring, plastica you want to be gentle and use low pressure (garden hose) or not directly hit with any water.
Old Aug 9, 2018 | 05:02 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
You guys who have used pressure washers......what nozzle were you using out of curiosity. I will be doing this to my engine bay shortly with a sealed partially assembled motor, just to clean up some not so meticulous previous owner cleanliness.
Old Aug 9, 2018 | 07:21 PM
Spaceme1117
I like a nozzle with a wide flat spray so that there is not too much water pressure on any given area and it will cover a wider area. Seems to cut grim better also.
To Pressure wash question
