C5 Instrument Cluster
Old 08-14-2018, 07:36 AM
ks376smith
ks376smith's Avatar
Default C5 Instrument Cluster
2001 Z51 with 72k miles.
The information display and the back lights are not operational.I removed the cluster and found several components burnt. I found replacement clusters on Ebay.If I replace the cluster will the mileage reflect the replacement cluster or the actual mileage on my Vette?
Old 08-14-2018, 08:04 AM
SG Lou
SG Lou's Avatar
The mileage is stored on the IPC and or cluster, whatever you want to call it.
Here's a thread that will give you the answer you are looking for :
https://www.corvetteforum.com/forums...-question.html
And if your game, you can swap out the module that stores the mileage from your unit to the one you purchase.
https://www.corvetteforum.com/forums...ansferred.html
Quick Reply: C5 Instrument Cluster
