Good route to go
Old Aug 19, 2018 | 11:18 PM
Temps_c5's Avatar
Temps_c5
Default Good route to go
I have a 02 base c5 I like to do pulls I can race mustangs and Camaros also trans am’s but it is hard to keep up with newer cars now and I wanted to know what would be the best way to go on a 450-480 whp I don’t want to go to crazy with supercharger or big cams so I’m asking you guys for for any advice on what to
Old Aug 20, 2018 | 12:11 AM
grantv's Avatar
grantv
150HP without big cams or forced induction? Nitrous? And a bit more...To keep up with the new quick cars, you'll need ponies and driveline mods. Takes a fair bit of money to do properly (be drivable and dependable).
Old Aug 20, 2018 | 04:45 AM
Tsumi's Avatar
Tsumi
As said, it would be very difficult with those restrictions. A LS3 swap with some bolt-ons might get you there without a big cam or forced induction, but makes less sense than a supercharger from a cost perspective.
Old Aug 20, 2018 | 11:18 AM
I agree. Without some heavy modding or a supercharger, getting to that power level is going to be very hard.
Old Aug 20, 2018 | 12:23 PM
Phanni's Avatar
Phanni
simply install a LT5
Old Aug 20, 2018 | 01:04 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Click on my profile, and look for threads I've started. 2000 6-speed build.
I am at 514 cshp, and 459 rwhp, all with bolt-ons, no forced induction or power adders.
The car runs like raped ape, and I love it.
Old Aug 23, 2018 | 10:53 PM
Time for a C-5's Avatar
Time for a C-5
You're pretty far down the rabbit hole to get to those numbers. Full heads/cam/intake/exhaust, all the support that's required, and once you've added the power your clutch just waived the white flag. Don't forget to rebuild the torque tube while it's out doing the clutch. And what the hell, swap the gear while the driveline is apart. No quick/easy solution for that power done right. That said, it's a blast when it's finished!
Old Aug 24, 2018 | 01:24 PM
c4cruiser's Avatar
c4cruiser
My '02 has a Vortec supercharger and puts down 450HP/410 ft-lbs torque at the wheels. There are no internal engine mods (stock cam, stock heads, stock exhaust manifolds). It does have an older Corsa Indy Pace Car cat-back and an X-pipe exhaust. It does have larger injectors to support the increased intake air and a water intercooler. The blower package came with a custom tune by SuprChips. When I bought the car, the seller showed me a couple time slips from his local drag strip and one showed a 11.6 ET and 127 MPH. What I like about this setup is that it drives like a stock C5 until you go WOT. A 1-2 **** at WOT will get the car waay out of shape And it still gets 30 MPG+ when cruising in 6th gear at 75!
Old Aug 24, 2018 | 11:31 PM
grantv's Avatar
grantv
I bet it does, probably enough to just about shift yourself.
To Good route to go
