Weather strip question
Old Aug 24, 2018 | 04:47 PM
Belba184's Avatar
Belba184
Default Weather strip question
I need to replace the weather strips that the driver and passenger side window seal against. Any idea what they are called. It’s not the door weather strips. It’s a 2000 coupe
Old Aug 24, 2018 | 04:49 PM
Belba184's Avatar
Belba184
And where can I buy them
Old Aug 24, 2018 | 04:57 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Do a search on Google for C5 Corvette Targa Top Weather Strip and you should get quite a few places that buy them. I think they call them side seals or something like that. If I recall correctly also, it's best to buy factory GM seals as the aftermarket isn't quite as good quality. I could be wrong though.
Old Aug 24, 2018 | 05:11 PM
Belba184's Avatar
Belba184
L
These are the weather strips I need
Old Aug 24, 2018 | 05:14 PM
grampi50's Avatar
grampi50
Also, once you get the new seals installed, GM makes a treatment for the seals that you can apply that makes them stay pliable longer...you can probably also find that by doing a search on this site...
Old Aug 24, 2018 | 06:40 PM
SG Lou's Avatar
SG Lou
I'm assuming the weather strip you are looking for are called outer window seals. To be honest with you I purchased a pair from Corvette America and they are identical to the OEM seals. Not to mention it was a hell of a lot cheaper. I think I paid 100 bucks for the pair. Been on the car over 2 years without a problem. As for the " SPECIAL TREAMENT" that you have to go to GM to buy, don't waste your money. Go to your local NAPA Auto Parts store and pick up a tube of Sil-Glyde. Been using it for years. The stuff works great and keeps the weather stripping soft and pliable. The best part is, if I remember correctly I paid 7 bucks for the tuba the stuff.
Old Aug 24, 2018 | 06:49 PM
redzg's Avatar
redzg
I think you're describing the 'upper weather strip', GM 10313371 (r/H) and 10313370 (l/h). gmpartsdirect gets $280 each for them. Yes, that's $280. Each. Plus shipping. Plus installation. I kind of need them as well, but have been put off a bit by the $600 plus installation. If you google the part numbers, you'll find a number of sellers and prices. If you search this forum, you'll find a considerable number of threads indicating the aftermarket versions don't work nearly as well as OEM. Unfortunately.
Old Aug 24, 2018 | 09:35 PM
grampi50's Avatar
grampi50
That's ridiculous for a couple pieces of rubber, but what they hey, they don't call it a Corvette tax for nothing...
Old Aug 24, 2018 | 09:39 PM
Ruouthere's Avatar
Ruouthere
Looking for weatherstripping myself last week for our '01, here's a good site to find the GM p/n's of which piece(s) you need: https://www.wholesalegmpartsonline.c...roduct=2572283
Next issue was finding the parts themselves, this site indicated they had what I needed, let me place the order only to be told 24 hours later the parts were obsolete and would not be available. So I called Eckler, gave them the GM p/n's I needed, they had a few in stock, received and installed them this week, good quality and fit perfectly. Hope that helps.
Old Aug 25, 2018 | 01:20 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I would only buy oem on those.
Ive purchased several sets of aftermarket seals from various vendors and the repros are very squishy at the ends and they have almost always leaked. Seems like the ends of the oem are injected with material so they have more firmness. Not super hard just more firm giving it some backbone where aftermarkets are like noodles.
Your call, but from my experience I’d get OEM or find a replacement used top altogether.
Old Aug 25, 2018 | 07:20 AM
Belba184's Avatar
Belba184
Thanks everyone. My c5 leaks on the door sills. I’m thinking I need the front windshield roof strip and that’s 750 bucks. Just for a piece of rubber ?????????? Any other fixes anyone knows of to stop the leaks
Old Aug 25, 2018 | 10:55 AM
envisi0n91's Avatar
envisi0n91
I'm right there with you. Bought the rear targa seal from gm, the side seals from steele, and now I dont know where to get the front one.
Old Aug 25, 2018 | 01:10 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Trim shop told me to put baby oil on the weatherstrips.
To Weather strip question
