Adding fogs to a Z06 question
Old Aug 30, 2018 | 09:24 PM
ss4luck's Avatar
ss4luck
Default Adding fogs to a Z06 question
So, I want to add fog lights to my Z, but dont like the idea of losing my brake duct wind screens OR adding the weird bucket thing the base madels have that shroud the fogs themselves. Can you run a fog light without the shroud? I figure the screen will hide any aesthetic blemishes that the shroud might hide/the bracket.
Would it be easier to buy a kit, or just fab up a everything myself?
Old Aug 30, 2018 | 10:29 PM
Don't see why you couldn't run fog lights without the shroud.
This file may give you some good info on installing the lights.
File Type: doc
Old Sep 1, 2018 | 05:52 AM
ss4luck's Avatar
ss4luck
Perfect thank you!!!
Is there a orefered vendor vendor to grab fog light kits from?
Old Sep 17, 2018 | 02:28 AM
Chrisrokc's Avatar
Chrisrokc
I had fogs in the car before. Should be a straight up mount and wire job. Just follow the OEM instructions. You can use the OEM switch plate/button.
To Adding fogs to a Z06 question
