C5 Fuel Pump Motor
Old Sep 4, 2018 | 08:13 PM
QB17's Avatar
QB17
3rd Gear
Default C5 Fuel Pump Motor
I have a 2002 base hatchback. I have been looking for the ACDelco fuel pump motor part number. I don’t want to buy entire assembly. I found ACDelco EP386. That fits Silverado (available at Autozone). Went to ACDelco site and it takes you directly to full assembly. Amazon has a few that will fit with some minor adjustments. Please help me out. Thanks in advance
Old Sep 4, 2018 | 09:24 PM
zachaeous's Avatar
zachaeous
There is a company called Racetronix that sells just the module. I purchased one a few years back from them. It worked out just fine. It was $150.00 for just the pump module.
It was a easy install and included everything needed.
Old Sep 4, 2018 | 11:09 PM
Thanks zachaeous for the lead.
Old Sep 5, 2018 | 03:33 PM
QB17's Avatar
QB17
3rd Gear
Is the Racetronix motor loud? I've read on this site that newer ACDelco is (improved) quieter. That's something I'm looking for. Current pump is pretty loud. No issues with it other than being loud
Old Sep 5, 2018 | 04:15 PM
Smoken1's Avatar
Smoken1
<br /><br />When was the last time you changed the fuel filter? A clogged filter will also make the pump run harder and louder
Old Sep 5, 2018 | 04:50 PM
zachaeous's Avatar
zachaeous
I noticed no increase in noise level from the stock to the racetronix pump. I also changed the fuel filter at the time of replacement.
Old Sep 5, 2018 | 09:23 PM
QB17's Avatar
QB17
3rd Gear
That's probably the best place to start. Fuel filter probably hasn't been changed ever. Less expensive fix too. Thanks
To C5 Fuel Pump Motor
