I'm looking over the instructions and i have a couple questions.
first is says make sure the steering is free. it is because i have a bypass installed in the steering column, so that's cool.
the question i have is this.. step 2a is removing the steering column lock relay.. with it already bypassed, is this step necessary? or leave well enough alone?
If your steering wheel is unlocked, then follow the instructions and remove the relay. I had no idea what was done to my car, so, I called the lmc05 manufacturer when I installed mine in July. They said their system bypasses the entire lock system and said to install it as in the directions. They did mention that since my car was a 2004, I could probably get away with not doing the brown wire mod, so I didn’t do it.
Thought I could get away with not doing the brown wire mod too, since mine is also a 2004, a month later I got the steering column lock warning and had to go back in and do it anyway. I’d say just do the brown wire mod, there’s really no downside.
reading the instructions, it says do the brown wire mod only if you get the service column lock post mod isntall.. to be clar, you are reccommending it regardless? and I am getting the pull key/scolumn lock message cosistenly, which is why I am installing the mod
OK it's in and seems to be working , i did nto get the dic messages. I did NOT disconnect that relay, I could not get both hands in there to get it loose, but i have the driver side CLB installed from a few years ago. I also took advice and did the brown wire mod. I'm hoping I am good to go.
