I recently got my car back from the dealer and I am curious to know if the parts I received were correct. I would like to double check a couple of things, and I need the following part numbers:
3rd, 4th, 5th, and 6th gears
Clutch assembly....if there is one part, but if not then I need the seperate part numbers.
I would appreciate any help, and by the way I got it back today and the problem I took it in for still isn't fixed.
I cannot shift into 4th gear with out a grinding noise.
I am sure it is the synchros and they say in the paper work I received they replaced it, but it still isn't fixed :mad :mad :mad
