[Z06] Question
Old Oct 25, 2002 | 07:50 PM
Adam B's Avatar
Adam B
Default Question
When I shift into third gear my car pulls to the left really hard...when I speed shift it...is this normal? Also when I shift into second at WOT the car wheelhops...Is this normal? Thanks
Old Oct 25, 2002 | 08:34 PM
ZO6Les's Avatar
ZO6Les
Default Re: Question (Adam B)
The car has the ability to make the rear step out to the left in gears 1-3, that is called HP :) Make sure you are running 30 - 31 PSI in the rear wheels, more reduces contact patch. And yes wheel hop is a problem that you learn to get around by experience and/or like I did by installing rear polu u bushings which helped all but eliminate it on my car.
Les
Old Oct 25, 2002 | 08:52 PM
Adam B's Avatar
Adam B
Default Re: Question (ZO6Les)
Thanks Les...I use to have a sprayed LS1 but it wouldn't spin through 3rd gear like the Z. This car rocks. :yesnod:
Old Oct 27, 2002 | 08:05 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Just use a bit of right rudder.
They ALL torque to the left, except jets.
To Question
