C5, as a first car?
like others have said ... insurance alone will be insane cost wise. Most folks get a reasonable first car that’s inexpensive to repair and keeps cost down. Get a few years of a good driving record. At 21 look to get a sportier car.
As an example, my 18 year old Son has a 2016 BRZ he recently purchased. He’s in the AIr Force. His auto insurance is $2600 for six months $5200 annually.
Good luck!
YetMan
Some will work and save but spend all of their income on insurance and gas and live with their parents. Many will drive it hard until they run out of $ for insurance and traffic tickets, then abandon the car for impound. (Yes I’m grouchy today.)
The smart ones will aim for a good job and get a beater. dependable used Japanese car for cheap is my suggestion, if OP can swing that. Or he’s a lifetime grease monkey, and his parents should settle in for the long haul.
-Insurance will be high and most likely price you out of ownership (even the most responsible male put behind the wheel will want to "play" in a car like a C5)
-At that sales price be expected to do a decent amount of maintenance depending on the cars history and if it was abused or not.
-Corvette tax IS real and unless you have been working your whole life with no bills (school loans/rent etc) to be able to fund a Corvette it may be difficult.
-Simple things like clutch work are much more involved. Since a clutch is a wear item and you looking at +100,000 mi cars this is something to consider. Or you can pay a mechanic to do it.
-Find a Civic/Crown Vic/Town Car/Mustang etc....something where parts are CHEAP and plentiful to get you used to car maintenance and costs. It will teach you brake jobs/oil changes/tune ups before getting into a C5.
I'm 32 and owned the following in following order
1986 Buick Delta 88 (first car bought from my Dad for $1)
1993 Chevrolet Lumina 4 door (it got neon lights and stereo equipment....not proud of it)
1993 Ford Thunderbird V6 (wheels/tires and exhaust work plus more stereo equipment)
1995 Lincoln Mark 8 (converted that from air bag to coil springs, exhaust work)
2004 Mustang GT (first manual car....THAT was an interesting drive home with my Dad after buying it LOL)
2004 Pontiac GTO (suspension/exhaust work and fixing many problem areas of that platform)
1999 Mustang Cobra (intention was to autocross/road race...never happened and sold it)
1995 Camaro Z28 (FULL suspension/motor work/exhaust work and autocrossed it for 3 years)
2004 Z06 (current car and bought 2 months ago.
My point is, as time went on I learned things along the way on Do's and Don't of car ownership. The C5 can be a costly experience as your first go-around.
Can you get a C5 for 12K? Yes. Will it need some work (which could cost you an additional 10K)? Probably.
You could land a very low mileage well maintained C4 for that price, but not a C5.
I think they are easy to work on, the car has a modular design where many parts are "plug and play", however they were a very advanced car for it's day and you would be wise to study up on the electronics involved. But it is a sports car, which means things are packed in pretty tight, so there are a lot of challenges. As far as being cheap in the future, if the price of new Vettes keeps going into the stratosphere like they've been doing, the only way post-C4 Vette prices are going is up, IMO.
I looked for a few weeks for the cleanest, newest and lowest mileage corvette that I could find for around 12k, thinking that I could get out of maintenance and repair bills for a while that way.
I eventually found a 2004 black on black m6 couple with 51k miles, no accidents and a clean title for 13,500. I went to look at it and it was pretty nice in person, but did have evidence of a light impact in the front bumper.
The paint was cracked and coming off in a small section around the front licence plate cover and the tires needed to be replaced. I took it for a test drive and it was a blast, but I did notice that the horn and front turn signals
did not work. I used all this as leverage to talk him down to $12,000 cash and thought I was coming out ahead with a low mileage garage queen, that needed minimal work..... lol Nope!
I drove it home and noticed that the handling seemed to wander around a bit and it also seemed to run a little hot when in traffic (around 230F).
Later on I noticed that the belts seemed to chirp a bit, especially when cold. I did my best to research on here and most said belt chirping is normal and "LS engines were built to run hot", so I brushed my concerned to the
side bought new tires (Toyo Proxes T1 Sport 265/40r17 front 295/35R18 rear) and an alignment for about a grand all together. The car handled much much better and actually put the power down to the ground. Fast forward
a few weeks and I start losing coolant and grow more concerned about running temperatures (car seems to always be around 230 to 235F), so I start looking for the source.
First to fail was the coolant expansion tank, so I replace the tank and cap and top the fluid off. A few days go buy and I am still leaking (Looks like its coming from the upper radiator hose) and running hot, so I replace the upper hose
and thermostat. A few more days go by and I am still leaking and running hot. This time I research some more and it seems the radiator end tanks fail after about 10 years (plastic dry rot and cracking just like the expansion tank).
I thought about going with fancy all aluminum radiator and expansion tank, but it seems as though the Chinese stuff is cheaper, but full of problems and the good stuff doesn't have problems, but is way too expensive, so I just get oem,
figuring if it lasts 14 years, its good enough to buy again.
I get around to replacing radiator and finally figure out why it seems to be running hot... The radiator and AC condenser are full of what looks to be about 14 years of leaves and road debris. Apparently this car is a bottom feeder and
literally scoops stuff off the ground and tosses it into the radiator/condenser, so periodic cleaning is necessary. I clean the debris off of the condenser, mount the new radiator and flush the coolant several times with distilled water before
finishing with a final mixture of 30% dexcool and 70% distilled water (its okay I live in Florida). The car runs much cooler and AC blows much colder at this point.
I get a few days off from worrying about the old girl breaking again and then the belts start progressively chirping and squealing louder. One day there is a loud bang, then no more squeaking and then my AC gets hot. ****. I pull over and
pop the hood. Yup, no AC belt. Luckily, the AC belt only serves the AC and the important stuff has it's own belt. So I do some research, think about what to do and pray that its just a tensioner or idler and not the compressor. I test it out and
everything is spinning free except the AC idler puller. So I decided to replace both belts, both idlers and both tensioners, just to be safe. That was about 300 bucks. It still chirps a bit on cold mornings lol.
I really want to do some fun stuff, like long tube headers, intake, tuning, c6z shocks, carbon fiber and window tint, but at the rate that I am going, I think all my money needs to be in a reserve fund for maintenance/repairs, since I am already
like $1500 in, in like 2 or 3 months...
You'll get to learn RWD on a very responsive and fun platform without a ton of horsepower getting in the way. They're good cars with more modern interior conveniences and safety. If you decide to autocross it, the consumables are cheap and it needs nothing to get started. Put a set of good snow tires on it and a couple sandbags in the trunk for winter and you're ready to rock.
I owned a BRZ for 3 years, it was a good car. A much better choice in your position than a Corvette, IMO.
https://www.ebay.com/sch/BRZ/175874/...p2045573.m1684
pop the hood. Yup, no AC belt. Luckily, the AC belt only serves the AC and the important stuff has it's own belt. So I do some research, think about what to do and pray that its just a tensioner or idler and not the compressor. I test it out and=left
Admittedly the guy was in a rush to sell because he was going to texas to pick up another, newer, Vette, but l personally don't think 125k mls is too high if it's got a FSH
& has a clean Carfax report?
But WTF do l know, l'm new to all this!
PS, quick question, can l use ordinary gas or do l need to use premium or even ethanol free gas?
There was not 1mpg difference & those 'bikes suffer no internal detrimental issues by using cheapest gas v dearest according to Triumph data.
Sorry to go off the OP's main subject, but l think he has a couple of years of thinking to do anyway!
https://www.angieslist.com/articles/...remium-gas.htm
