Where to find?
Old Dec 27, 2018 | 02:44 PM
jimmyj333's Avatar
jimmyj333
Cruising
Default Where to find?
where would I find these for the front air deflector? Need a total of 4. Can’t find anything on parts warehouses or diagrams
Old Dec 27, 2018 | 09:34 PM
redzg's Avatar
redzg
I have seen a thread where a member noted having made his own. If I might suggest, think about obtaining a reproduction center section and cannibalizing the wire retainers from it. $68 on Amazon.
Old Dec 27, 2018 | 10:21 PM
jimmyj333's Avatar
jimmyj333
Cruising
Ya saw a video made by Froggy, now that I have an understanding what I am looking at it will be off to the hardware store
Old Dec 30, 2018 | 12:54 AM
Good luck - please post up what you find.
Old Dec 31, 2018 | 10:21 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Yes, I made a few wire tabs, there is a video by froggy is on youtube on how he repaired his. I go through these quite a bit, lowered car and driveway curb don't get along.Can't post pick but found old post:
https://www.corvetteforum.com/forums...placement.html
Made these in a hurry, just wanted to get the car on the road after changing oil cooler lines. Will probably find a better solution, with some sleeves on the cable or a bushing on the metal where the cable goes through. That's where it slides and breaks. Heck, my metal is getting slots worn in from the cables. I used picture hanging wire, doubled up and some 1/4" compression nuts with a small washer inside the nuts to loop and hold the wire, filled the void with caulk so it looks flat and a little paint. It probably won't last long, but a temp fix. Always open for a better solution, can't keep buying center spoilers for stupid cables, lol.
To Where to find?
