yes I wasn’t to impressed with the factory radiator. I put a 180 degree thermostat in and the best it got down to is a 192 degrees. Which is good right now but not when it starts heating up here in Arizona. Yeah I think Chevy really cheap out on the radiator. It makes you wonder how many things go out on a Corvette early because things got to hot.
Good choice. First real upgrade I did to mine as it started overheating at the track. When I took it out to repl with DeWitts, there was so much crud in there, I probably didn't need to repl, but did anyway. Rad as held up well in over 9 years of track days. I take it out during the winter and clean it well. Can't imagine the the Ron Davis one being worth the extra dollars, so excellent choice..
That’s good to hear it’s doing the job and no problems. I’ve heard when you run at the track things heat up big time.
You're going to have no problem with cooling with that rad, having the fans on their stock temps. Unless you start putting big power in the engine, I don't see the need to tune the fans on earlier. Just my opinion using real world experience.
You're going to have no problem with cooling with that rad, having the fans on their stock tein stop anmps. Unless you start putting big power in the engine, I don't see the need to tune the fans on earlier. Just my opinion using real world experience.
With Arizona temps between 110 and 120 while stuck in traffic, I am not so sure.
Yes, I agree, but it will not keep temps at 180 without the fans kicking on earlier. Fans do not kick on, even with AC on until temps get to 185. If the OP wants to keep temps at the thermostat rating of 180, fans will need to be adjusted.
My buddy was an engineer for Ron Davis radiators here in AZ and he recommended that I keep the stock radiator when I mentioned that I was thinking of changing out for a DeWitt. He pointed out that all aluminum radiators will suffer leakage eventually at the welds (vs the plastic tanks that "float" on the factory radiator). He also pointed out some other issues such as steel or brass fittings in aluminum creating galvanic corrosion. (PS I'm not an expert, he just mentioned all of these when I was looking at the Aluminum radiator at the local speed shop).
As he pointed out, all the hot weather testing for the C5 was done right here in Mesa, AZ, and the C5 is meant to run at higher temps that the 180 we are used to in the old days. I haven't owned my 04 C5Z long enough to weather an AZ summer, so we shall see. I'll probably pull the condenser to blow out all of the garbage that accumulates in the rad and condenser as a first step.
