Fancy New Wheels For My FRC
Thanks! They do have bolts since they’re two-piece rims, but the bolts are on the inside of the face only visible when the wheels are off. I agree, much better/cleaner looking without them
Looking forward to seeing them installed! I lovvvvve Fikses!
Fikse Technipolish is actually an anodize. It cannot be polished nor stripped off conventionally.
I had a muffed up set of FM5s I decided to recondition once. Aircraft stripper may remove any clear top coat but it will ZERO to technipolish. Hit it with a wheel and compound all you want afterwards. Nothing. It must be chemically stripped or sanded off.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Those look awesome, love them.
Received 1,227 Likes
St. Jude Donor '11
Thank you everyone! I polished the lips with Mother’s aluminum polish and a lot of elbow grease. The faces are Technipolished so they’re essentially polished aluminum with clear coat. Those I treated as a painted component and used polishing compound with a small orbital buffer.
