I bought a set of LED lamps from the Radio Flyer These lamp assemblies are a true "plug-n-play. No need for a special hyperlink wiring harness. Just remove the OEM lamp housings, disconnect the OEM wiring harness from the housings and plug in the new lamps. Then install the new lamps using the OEM screws.
True, these assemblies do cost a fair amount, but they are very well made and work great. And the owner (George) is a great person to work with and he is a CF Supporting Vendor. Lots of CF members have bought lighting accessories from him and they highly recommend him.
True statement. You can't go wrong with radioflyer. George is a stand-up guy.
Top-notch product.
I got mine from Corvette Envy. They are LED, but with the halo's, went with the premodded ones that keep the halos active with the running lights. Looks great IMO. Haven't had a single issue with them, and I always love seeing them as I'm walking up to the car or anytime they're lit.
Our "Halo Modified" tail lights are a popular way to both modernize the look of our corvette and increase safety. The Brake light function is incredibly bright and the instant-on of the LED function gets attention faster than the standard bulbs. They are plug-and-play, install in less than 5 minutes (especially if you have a cordless drill). and will out-last your car.
