LS1 Water Pump Replacement
Jan 20, 2019 | 08:14 PM
I'm going to replace the water pump on my 2004 Corvette LS1 and have read alot of info. here and elsewhere on the web.
There are several options. What do ya'll recommend? Thanks, Hal
Jan 20, 2019 | 11:29 PM
Jan 21, 2019 | 12:20 AM
I replaced mine with this back in 2016, no issus at all. Works great
Jan 21, 2019 | 12:25 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
make sure you get gaskets with whatever you buy
Jan 21, 2019 | 11:04 AM
I also would go with an OEM unit. Hard to go wrong that way.
Jan 21, 2019 | 11:35 AM
Quote:
Originally Posted by
jdmvette
I used this one in 2014
Jan 21, 2019 | 02:04 PM
How did you know it needed replacing?
Jan 21, 2019 | 02:16 PM
AC Delco....$95.00....includes gaskets....look for them under the bottom flaps in the box....
Jan 22, 2019 | 10:05 AM
The only "trick..tip", I can think of is to put 3M adhesive on the pump and gaskets to hold them on while lining up to put the bolts in.
Jan 22, 2019 | 11:04 AM
jjc508520
Coolant dripping all over the place. If your accessory belts are wet look at replacing the water pump ASAP. It's not a difficult job.
Jan 24, 2019 | 01:27 PM
Water Pump
Thanks to all that responded. Has anyone used a FlowKool water pump?
