Tranny/diff mount question.
Old Jan 30, 2019 | 07:41 PM
Georgies's Avatar
Georgies
Default Tranny/diff mount question.
Hi all, I recently purchased a "one off" tranny/diff mount from a member here. He said the design is based off Pfafts mount.
After checking it out, it seems that the bore for the center bushing is too big. Is it normal to have some play between the two parts?
Heres a vid showing my concern.
Old Jan 30, 2019 | 10:02 PM
StingrayRebel's Avatar
StingrayRebel
seems like the hole was machined a bit too big... I had a pfadt mount before I did a tr6060 swap and it wasn't loose like that... maybe you can find a bigger bushing that fits that hole tighter
Old Jan 30, 2019 | 10:05 PM
Georgies's Avatar
Georgies
Damn... i could machine my own bushing but the only material i have is teflon, and i think that would be too hard.
Do you Know what material i should use?
Old Jan 30, 2019 | 11:57 PM
TrackAire's Avatar
TrackAire
Might be easier to put a sleeve in the machined hole to tighten up the tolerance instead of trying to machine a whole new bushing.....that way you can use your existing bushing.
Old Jan 31, 2019 | 10:50 AM
Cutlassmaster's Avatar
Cutlassmaster
Could you add a sleeve to the small part in the middle for the bushing? Otherwise make your own if you have materials and machines to do it. That way you are only out a little bit of time.
Or could you make that center sleeve bigger so it expands the bushing? Just like the control arm bushings when you put the sleeve in it makes them expand and get really tight.
Old Jan 31, 2019 | 12:03 PM
Smoken1's Avatar
Smoken1
I have seen that mount in the Facebook groups. You may want to look him up over there and see what he says..
He is also trying to do the Pfadt engine mounts
Old Jan 31, 2019 | 10:58 PM
Georgies's Avatar
Georgies
I have a lathe and can source the material. I just need to know what material to use. I dont have facebook so...
The kit comes with a sleeve in the center of the bushing, to bolt the center to the cross member mount. I wonder if its a crush sleeve??
Old Feb 1, 2019 | 05:06 AM
Cutlassmaster
I doubt that is a crush sleeve but if you could find one that is a little bigger it will expand the bushing and may give you what you need.
Old Feb 1, 2019 | 10:34 AM
Georgies's Avatar
Georgies
Ok in this case i think id rather make a new bushing. Im going to call a local rubber supplier and see what material they suggest.
I have teflon but im thinking it may be too harsh on the mounting point to the diff. What do you guys think??
To Tranny/diff mount question.
