Dashboard lights
Old Feb 17, 2019 | 10:37 AM
Hubb 97's Avatar
Hubb 97
Cruising
Default Dashboard lights
A couple nights ago the dashboard lights on my 98 went out while driving home. The headlights work for brights and dim, but the lights won't go down. The DIC works as normal. Does anyone here know if this is probably a bad relay, and which relay it would be? Would it be under the hood, or under dash on passenger side? Thanks for any help : )
Old Feb 18, 2019 | 09:10 PM
Hubb 97's Avatar
Hubb 97
Cruising
126 views and nobody has an answer : (
Old Feb 22, 2019 | 01:58 PM
lucky99's Avatar
lucky99
Sounds like a Body Control iModule.
Old Feb 23, 2019 | 04:22 AM
ncali's Avatar
ncali
I think it is fuse 19 inside that when removed or burnt will cause the headlights to not go down, and dash lights not to work
Old Feb 23, 2019 | 09:17 PM
Hubb 97's Avatar
Hubb 97
Cruising
Wow, that would be awesome!
To Dashboard lights
