headlight replacement with flush mount.
Old Feb 21, 2019 | 04:46 PM
crx1989's Avatar
crx1989
Cruising
Default headlight replacement with flush mount.
Is there a a replacement that stands out from the rest. I'm getting tired of my lights not coming up.
Old Feb 21, 2019 | 05:09 PM
USAZR1's Avatar
USAZR1
Radioflyer makes some nice flush mount headlights but they are pricey.
Old Feb 21, 2019 | 05:26 PM
Tsumi's Avatar
Tsumi
Radioflyer is the only worthy choice. He's recently upgraded them to LED projectors as well
Old Feb 21, 2019 | 07:17 PM
knewblewkorvette's Avatar
knewblewkorvette
Here you go:
https://radioflyerinnovations.com/sh...-v3-headlights
Old Feb 21, 2019 | 08:10 PM
crx1989's Avatar
crx1989
Cruising
Default wow
Thanks for the recommendation but wtf. $1200. I was thinking $400 or less.
Old Feb 21, 2019 | 08:11 PM
crx1989's Avatar
crx1989
Cruising
Default wow
Sorry, shouldnt say wtf. I appreciate the input but that is more than my budget allows.
Old Feb 21, 2019 | 08:49 PM
Tsumi's Avatar
Tsumi
At least $600 in just the projectors. Plus all the custom fabricated parts, which are all low volume high quality.
FYI, you cannot get a proper HID or LED headlight for any car for under $400. The projectors alone are at least $250 at the low end.
Old Feb 22, 2019 | 04:45 AM
crx1989's Avatar
crx1989
Cruising
Default Reset
Thank everyone for the input. I think I may have to go at it from a different angle. Maybe I need to start a new thread but here goes. How do I get the headlights to pop up every time like clockwork instead of having to pop the hood and turn the motor **** to get the headlight to come up? Usually the left comes up on a regular basis but the right regularly doesn't.
Old Feb 22, 2019 | 08:37 AM
73Corvette's Avatar
73Corvette
This is going to sound like a real smart aleck answer... fix it.
There is a ton of information on headlight repairs, gear replacement etc... do a little research and fix them...
https://www.corvetteforum.com/forums/c5-general/4164157-must-read-the-definitive-c5-info-thread.html
Old Feb 22, 2019 | 11:35 AM
GCG's Avatar
GCG
...How do I get the headlights to pop up every time like clockwork instead of having to pop the hood and turn the motor **** to get the headlight to come up? Usually the left comes up on a regular basis but the right regularly doesn't.
​​​​​If manually relieving the pressure allows it to work and the motor works fine closing, while not producing the well known "rat-tat-tat" noise, chances are your motor is OK and it is just the bump stops that limit the closing action what needs to be replaced (even though they might look fine to the naked eye). The ones that limit the opening action are probably fine, but I would replace all 4 (it might be a good idea to do the same to the other side as well).
The way the headlights work is not based on predetermined positions. When the headlight doors open or close and they reach the end of their travel, they press against the corresponding rubber bump stops. As a result the current through the headlight motors increases and that is sensed by the Headlight Door Control Module, which in turn cuts power to the motors.
If there are missing or damaged bump stops, or they are scored too deep, the motor might keep working longer than really needed, which could result in over torque. If that happens, the next time the motor is operated it would require more torque to perform the action. That would mean more current than normal and the possible intervention of the Headlight Control Module, shutting again the motor before the door actually moves.
If you need replacements you can order them from here.
In addition to that, there is a TSB for the driver's side headlight motor that calls for shimming it.
Old Feb 22, 2019 | 11:49 AM
jglassmaker's Avatar
jglassmaker
There is the cheap option for fixed headlights - Depo housings. You can get them on Ebay for like $300 (I have a used pair also I'm going to sell). The issue with these is they give you a "frog eye" look and are not completely flush with the body like Radio Flyer's are - I have switch to Radio Flyer's after about 2 years with the Depo "frog eyes" - never going to flip ups again so selling my stock headlight assemblies this weekend actually.
Old Feb 22, 2019 | 01:58 PM
USAZR1's Avatar
USAZR1
[QUOTE=jglassmaker;1598927514]There is the cheap option for fixed headlights - Depo housings. You can get them on Ebay for like $300 (I have a used pair also I'm going to sell). The issue with these is they give you a "frog eye" look and are not completely flush with the body like Radio Flyer's are - I have switch to Radio Flyer's after about 2 years with the Depo "frog eyes" - never going to flip ups again so selling my stock headlight assemblies this weekend actually.
[QUOTE]
Just a suggestion only but I would hang onto to your stock headlight assemblies. They are becoming harder to find and commanding lots of money.
Old Feb 22, 2019 | 02:39 PM
jglassmaker
Good idea, but I've held onto them for about 3-4 years now and it was time to clean out all my old spare parts for space. I need a house with a garage asap
Old Feb 22, 2019 | 02:45 PM
RapidC84B's Avatar
RapidC84B
Great post! Save the popups! I had one of the first set of SpecterWerks on my old 2001 C5 Z06. It was the coolest thing ever back in the day; C5-R look. Then the C6 came out the proper integrated fixed lights and the C5-R style looked silly. Now nearly 20 years later the pop-ups are unique and rare and I love them.
Old Feb 24, 2019 | 01:01 AM
striper's Avatar
striper
Aside from replacing the bump stops as mentioned previously, you should also replace the nylon gear with a brass gear. There was also a TSB that suggested putting a washer under the heads of the three bolts that mount the headlight motor to the frame of the car to space the motor away a little bit. All of these parts can be sourced from www.rodneydickman.com. He has everything you will need to fix this permanently.
Old Feb 24, 2019 | 08:26 AM
grampi50's Avatar
grampi50
You could do the "frog eye" mod as jglassmaker suggested, but they are extremely ugly IMO...I'd rather just fix the pop-up headlights...
Old Feb 24, 2019 | 04:39 PM
Velocity_Vette's Avatar
Velocity_Vette
I don't understand why you don't just fix what you have if it's having problems. The diagnosis process for the headlight assemblies is well documented and the most expensive thing you may possibly have to buy is a headlight relay box or a new motor; both of which can be had through re-sellers affordably.
Buy the ones you see online for under $400 and a few months later post the reason why you realized you just wasted $300-$400.
To headlight replacement with flush mount.
Old Feb 24, 2019 | 04:58 PM
v8srfun's Avatar
v8srfun
When I bought my c5 it had the frog eye lights and I will say they suck. The light pattern is horrible and I felt like I would have been better off with a flashlight taped to my hood. Now I have stock flip up lights and they are ok but still leave much to be desired. I also am budget conscious and will not spend radio flyer money so I just deal with the stock stuff. I hear euro housings are a good upgrade but at that point you might as well spend the money on radio flyer because the euro housings are outrageous in price too.
Old Feb 24, 2019 | 10:02 PM
Forcedvert's Avatar
Forcedvert
Just fix them......unless you like the look of fixed lights.. But as suggested above, keep the original stuff........last of the pop ups
Old Feb 25, 2019 | 07:18 AM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
As others have recommended... just fix them.
That's what I did... brass gears etc. and upgraded the housings/lights (to HIDs) at the same time.
