o2 sensor adapters..
Old Feb 25, 2019 | 04:25 PM
04zjimc's Avatar
04zjimc
Default o2 sensor adapters..
Im looking for the adapters that allow you to use the rear o2's in the front for my 04z...does anyone have a set or know where i can get them? Thanks
Old Feb 25, 2019 | 04:51 PM
StingrayRebel's Avatar
StingrayRebel
I prefer to repin the rear o2 sensor wires into the front o2 connectors, there isn't a lot of space in that area and it gets cluttered up using adapters... just an alternative to consider that won't cost any money
Old Feb 25, 2019 | 05:58 PM
1999corvettels1's Avatar
1999corvettels1
Is this for installing headers?
Old Feb 25, 2019 | 06:32 PM
04zjimc's Avatar
04zjimc
yes it is..
Old Feb 25, 2019 | 06:35 PM
04zjimc's Avatar
04zjimc
yes space is limited...thats not a bad idea! The pins fit in the front even though the connector is different?
Old Feb 25, 2019 | 07:28 PM
StingrayRebel
yeah just make sure to put them in the correct slot but they should be labeled A, B, C, D
Old Feb 26, 2019 | 10:43 AM
04zjimc's Avatar
04zjimc
my car is a 04..so aren't the front and rear o2 connecters the same square? If thats the case then i just need to swap sensors...?
Old Feb 26, 2019 | 11:20 AM
StingrayRebel
not sure about the difference in years but if the connector is the same then yeah just plug it up
To o2 sensor adapters..
