valve cover gaskets
I'm a little confused.
When did they start selling single gaskets? I always thought they came in pairs.
I have the perimeter bolts. I want to get new grommets/seals for them.
Everything out there comes in packages of 8. I have 9 bolts.
Can you buy them individually?
It seems parts for the 97-98's are hard to come by sometimes.
theyre the 4 bolts Running parallel with the long sides of the cover, in the middle of each. Any other bolt would just be for coil brackets, not actually the valve cover.
so then to the OP, ensure you have the right valve cover gaskets!
dbgoodwin, I'm good with the gaskets.
mstromquist, I took a real close look at the bolts. Each one has a metal washer with a rubber/poly bushing. I want to replace them after I spotted some oil around them. I tried to remove a bolt and it wouldn't let me pull it out. I tried another bolt and it would unscrew but not release to come out. I've changed v c gaskets before but never ran into something like this. LOL.
While I feel that this is "wimping out", it also creates a unique situation. When you buy new gaskets, the parts stores have a reasonable "turn over" of their inventory, so the gaskets you buy, are usually "fresh", therefore pliable. Grommets, since many people "wimp out" and reuse them, can get dried out, while sitting on the store's shelf, and when you go to install them on the bolts, they'll tear. I had this happen, a couple of years ago. If you choose to replace the grommets, which I suggest, inspect the new one carefully, and make sure they're not dried out. Also, soak them in hot water, before installing them on the bolts. This makes them pliable, and far easier to slip on the bolts.
