Convertible side window adjustment?
Old Mar 21, 2019 | 10:57 PM
lunaticfringe007's Avatar
lunaticfringe007
Default Convertible side window adjustment?
Had to have the passenger door adjusted because it was not closing properly. Now I hear more wind noise through the passenger window. I notice it is slightly lower than the driver side. Cant they be adjusted? If so does anyone know how to adjust it?
Thanks-
Old Mar 22, 2019 | 06:34 AM
Grandpa1's Avatar
Grandpa1
Yep. There are all kinds of tips and tricks about doing it. None of it worked for me.
I even took it to the dealer for them to adjust it. Spent 80 bucks for nothing.
I ended up going to Harbor Freight and buying a 4" suction cup and taking the door panel off.
I loosened the two bolts that held the glass in and gently closed the door. I then took the suction cup and fastened it to the outside of the glass and moved the glass where it needed to be to seal off. I opened the door and tightened the bolts. I put the panel back on.
Viola? No more leaks for a year and a half now! No more wife griping about wind noise! No more water leak when washing the vert!
Good luck!
Old Mar 22, 2019 | 07:47 AM
lunaticfringe007
Good luck!
Ok. That does not sound too difficult. I see a trip to harbor freight in my future.
To Convertible side window adjustment?
