[Z06] LS2 C5 swap questions.
1. How did you guys run your knock sensors? I can't find a solid answer on how to run them on the forums I know one is a single plug and the LS2 is a dual wire design, do I have to drill or tap into the block? Let me know.
2. What is your valley cover/Pcv setup? I have holly valve covers will be running PCV from my Mighty Mouse to them but there is also a bung on the LS2 valley cover help is appreciated thanks.
