Bcm
Old Mar 26, 2019 | 04:40 PM
Jerry Seyb's Avatar
Jerry Seyb
4th Gear
Default Bcm
What years BCM r interchangeable with a 98 I found one on line but it's from a 2001 the last 4 digits from the VIN r w5106947 any help would be appreciated
Old Mar 26, 2019 | 04:46 PM
Phanni's Avatar
Phanni
The BCM is programmed for each individual car. You'll need to find one from a early C-5 (pre 2001) that fits your car (coupe, vert, Z06) and have someone that can program it to your car's features. Dealerships can do this, and a few others that have access to the correct device.
Old Mar 26, 2019 | 04:52 PM
Jerry Seyb's Avatar
Jerry Seyb
4th Gear
. Thanks a 2001 will work then. I have someone to program it.
Old Mar 26, 2019 | 10:01 PM
wdcraig's Avatar
wdcraig
Jerry, I don't think the '01 part will work on your car based on the advice Phanni provides. Phanni advised you:
"The BCM is programmed for each individual car. You'll need to find one from a early C-5 (pre 2001) that fits your car (coupe, vert, Z06) and have someone that can program it to your car's features. Dealerships can do this, and a few others that have access to the correct device."
If I read your post correctly, you have a 1998 Corvette and the 2001 Corvette part you found will not be compatible with your older Corvette.
Old Mar 26, 2019 | 10:16 PM
Jerry Seyb's Avatar
Jerry Seyb
4th Gear
Default C5 bcm.
Thanks I called the dealership and the 97 and 98 C5 BCM will only work in those years. The later c5s bcms 01 to 04s r interchangeable I don't know what happened to the 2000s nothing listed.
Old Mar 26, 2019 | 10:18 PM
Jerry Seyb's Avatar
Jerry Seyb
4th Gear
Default Bcm
I found the right one on eBay remanufactured by cardone
Old Mar 27, 2019 | 02:32 PM
Phanni's Avatar
Phanni
If the options on the car are an exact match, no programming will be needed. However the likelihood of that is to good.
To Bcm
