Headlight upgrade
Old Apr 18, 2019 | 02:36 PM
scsete26's Avatar
scsete26
Default Headlight upgrade
Hello everyone! Looking to upgrade my factory high/low beams with some new bulbs. Any suggestions on best bulbs for me to buy?
Old Apr 18, 2019 | 02:59 PM
Triplex07's Avatar
Triplex07
I tried the LED Upgrade Bulbs. Was not happy at all. You have to install a resister in order for the headlights to work properly. Which is fine until you see how hot the resister gets .. I ended up taking them out and just getting some better bulbs at the local AutoZone.
Old Apr 18, 2019 | 04:41 PM
rrwirsi's Avatar
rrwirsi
In addition to the better non LED bulbs, I suggest getting Radioflyer's Hi-4 Harness that allows both high and low beam on at the same time. You may also consider obtaining Radioflyer fog light bulb replacements if your car has the fog lamps. They really help in illuminating the dark streets without light.
Old Apr 18, 2019 | 05:54 PM
Rexde1's Avatar
Rexde1
I just installed the sylvania 9006 silverstar 2xe gold low beam biulbs. It is an improvement over what I had but not crazy different. I am happy with the results with night driving and cost 60 bucks a pair. I may now change the high beams because the lows are much whiter looking now.
Old Apr 18, 2019 | 06:13 PM
Tsumi's Avatar
Tsumi
Look up the HIR 9012 and 9011 mod, takes the place of 9006 and 9005 bulbs respectively.
Old Apr 19, 2019 | 07:16 AM
Simtech's Avatar
Simtech
The Hi-4 makes a world of difference. If you can do a little electrical work yourself its not hard to build one, I think I got the drawings off of the Radioflyer web site. I just checked and the drawing is still there but they are now only $25 so you cant beat that price. I had all of the parts laying around so I just did it myself, Free is even cheaper.
Old Apr 19, 2019 | 04:48 PM
mrlmd's Avatar
mrlmd
HIR bulbs are a great improvement but need to be modified a little (easily done) to fit into their sockets correctly, or go the next step to HIDs. Many vendors on here and the price varies a great deal from ~$370 to $1200.
Old Apr 19, 2019 | 09:28 PM
Drice0217's Avatar
Drice0217
I purchased my led headlight from Vette Lights.. Had the resister already wired in. Was easy to install and made a huge difference..
Old Apr 19, 2019 | 09:35 PM
MG23FRC's Avatar
MG23FRC
Would you recommend this set up? I have been thinking about going this route.
Old Apr 19, 2019 | 11:27 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Default Head
What is this resister you mentioned? Is it the same thing that I installed when I put my led tails to stop hyper flash?
Dave
Old Apr 20, 2019 | 06:22 AM
peteinpa's Avatar
peteinpa
I just installed the HIR replacements 9012, 9011. Huge improvement.
Old Apr 20, 2019 | 11:03 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
George @ RadioFlyer Innovations has the best. I had a custom pieced kit, then a kit from another vendor... Poor performance and failures even with their looms. Went to George and the product is top notch as well as gaining supreme night driving. I went with the low rise, but he has a bunch of options.
Old Jun 20, 2019 | 07:58 PM
PlanoLeMans's Avatar
PlanoLeMans
I don't understand the resistor comment on led headlights. They are needed to solve the hyperflash problem on the turn signals. You can run led headlights without in line resistor.
For the high four harness just buy a relay and wire it in to trigger off of the high beam to supply power to the low beam. I did it for around a couple of bucks.
Old Jun 20, 2019 | 08:41 PM
Golfingbob's Avatar
Golfingbob
Just did the 9012 HIR Upgrade today. Very easy. Will take it for a spin this weekend to see the difference.
Old Jun 21, 2019 | 12:33 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
The resistor is used to get the headlights to retract or lower when you turn the lights off. With the low voltage of the LED headlights they won’t go down when you turn them off.
Old Jun 21, 2019 | 09:45 AM
PlanoLeMans
Ok i see your point. I had no issues without resistor in line.
Resistance iwould not be my first choice to handle that. Just rewire how the motor is getting power would have been my choice had i encountered that problem.
To Headlight upgrade
