VVT in a C5
In a recent Hot Rod they took a GM VVT engine (an L98 - from a truck/SUV I believe) and put nitrous on it. Which got me thinking - has anyone swapped a VVT engine into a C5?
https://www.roadandtrack.com/car-cul...work-benefits/
Also, of course a cam from the factory is going to be geared towards fuel economy. There are performance VVT cams available.
btw...my example was from driving both not looking up specs, there were a few other factors like the non VVT truck had 410 gears and a 4 speed the VVT truck I think had 342 gears and a six speed soo it was really less than I stated for economy in my real world example.
The lt1 has a little more torque down low than an ls7, which could be potentially attributed to the vvt, but who cares about that? No LS is lacking in torque to begin with.
Also, a C7 is apparently more efficient at hypermiling than a C6: https://www.popularmechanics.com/car...-run-16686407/
However, a large V8 in any car is going to get bad city mileage primarily due to the tendency to accelerate faster than you would without that power. That and the fact that a large engine will consume considerably more fuel than a smaller engine while idling.
I got a calculated 31.3mpg at 70 miles an hour driving from nc to Florida, including traffic through Atlanta. On the way back I got 30.5 because I was able to move quicker without my parents following me in their mazda3 with kayaks on the top.
He hypermiled a c6 and only got 32? People report that kind of highway mileage at normal driving styles.
Ill say it again, in the real world, vvt and dod don’t really help the corvette.
Good points made that VVT probably won't add peak power over a non-VVT - just perhaps "move it around".....
VVT basically just gives you two cam profiles that can be switched on the fly. There are VVT cams available that are more aggressive than the factory cams.
The VVT system on late model dodge vipers actually employs a cam within another hollow camshaft to allow the exhaust centerline of the cam to be adjusted independently of the intake centerline, which allows adjustment of overlap, so you can get hot cam topend with mild cam idle/emissions....
Generally advancing intake adds lowend, retarding intake adds top end, while the exhaust is opposite with retarding exhaust adding lowend and advancing the exhaust adds topend. The intake phasing has more of a profound effect than the exhaust phasing, so with GM's single cam phasing, the rules of intake phasing will apply to GM's overal phasing.
This isn't to say that GM putting vvt on their pushrod engines isn't beneficial. It obviously has its pros. I am sure it helps a good deal with efficiency and emissions. Also they could run slightly hotter cam specs that would normally hurt lowend/efficiency/emissions, but due to being able to adjust the cam phasing on the fly, the engine could keep the lowend/efficiency/emissions of a milder cam, while still benefiting from the added top end of the hotter specs. This also works vice versa, as GM's VVT is capable of advancing the cam up to 7 degrees for added lowend and retarding it up to 45 degrees for added topend.
Most people just delete or lock the cam phasing on these GM engines, when they put a big cam in them, so they don't have to worry about valve to piston clearances, but if you know what you're doing, you can greatly benefit from vvt adjustments. This article explains it better than I ever could:
https://www.hotrod.com/articles/hrdp...formance-test/
https://www.mechadyne-int.com/home/dodge-viper/
