Creaking noise under hard acceleration
Old Apr 25, 2019 | 01:13 PM
Sean_emory's Avatar
Sean_emory
Default Creaking noise under hard acceleration
I’m getting a fairly loud and nasty creaking noise under hard acceleration around 4-5k RPM+ in first and second gear. Sounds like its coming from the rear end but it’s hard to diagnose. Anyone dealt with this? It’s a 6 speed.
Old Apr 26, 2019 | 02:00 PM
Sean_emory's Avatar
Sean_emory
No one? My car is just royally effed?
Seens to mostly go away once the car has been driven for a while.
Old Apr 30, 2019 | 10:54 PM
Sean_emory's Avatar
Sean_emory
Any ideas guys?
Old May 1, 2019 | 12:40 AM
BodymanBob's Avatar
BodymanBob
Default Noise
I’m assuming that you’ve had a professional mechanic listen and actually HEAR the same noise you’re hearing, correct? If he has heard the noise did he put your car on a lift and check all the bolts on the rear suspension to see if any are loose or incorrectly torqued down. Once in awhile just loosening everything in the back and then torquing it back in the correct order and ft/lbs will stop a noise under load. It’s so hard to identify a noise under power while it’s at rest on a lift. Noise from a car can be annoying at the very least . and potentially a warning of a bigger issue. Good luck, let us know when you find it.
To Creaking noise under hard acceleration
