Clear coat?
Old May 16, 2019 | 10:02 AM
StatmanRN's Avatar
StatmanRN
Default Clear coat?
C5, Tuxedo black. Was the original paint single stage, or base coat/clearcoat ?
Aso, was the acrylic top clear coated?
Old May 16, 2019 | 10:18 AM
glbeauchamp's Avatar
glbeauchamp
Almost positive it is base/clear. Don't know about the top but I doubt it is painted.
Old May 16, 2019 | 11:55 AM
c4cruiser's Avatar
c4cruiser
GM uses a base coat/clear coat on all of their vehicles. Pretty sure the acrylic top does not have a coating.
Old May 16, 2019 | 12:23 PM
v6turbo87's Avatar
v6turbo87
GM stopped using single stage paint in 1987
Old May 16, 2019 | 12:30 PM
vetteLT193's Avatar
vetteLT193
Fun fact... all Corvettes built in the Bowling Green plant have been Base Coat / Clear Coat. So the swap to base/clear was in 1981.
Old May 16, 2019 | 02:06 PM
Fcar 98's Avatar
Fcar 98
The clear top in clear coated. Don't use anything on the top that you wouldn't use on the painted surfaces.
Old May 17, 2019 | 08:53 AM
StatmanRN's Avatar
StatmanRN
Thanks. Thought so, but wanted confirmation. I knew the 95 I had was.
I have some crazing on the upper surfaces thanks to FL sun. Not the burn through like the 95v had though. Spent a lot of time wet sanding and polishing recently. Its much better, but I think I will need to shoot new clearcoat at a minimum if not repaint the hood and rear deck.
Old May 17, 2019 | 11:15 AM
Fcar 98's Avatar
Fcar 98
I use a polish that has UV protection. Zanio.
To Clear coat?
