This Forum Did It Again
Old May 24, 2019 | 07:33 PM
ALLEGRO's Avatar
ALLEGRO
Default This Forum Did It Again
I browse this forum nearly everday. It is entertaining to me to see "yester-year's" topics emerge yet again. Very cool if you ask me.
So......was reading about the anti-venom mod, and after 16 years of ownership, I decided to take it on.
No real big deal. The nut was OE installed a bit tighter than the 30lbs of torque listed, but all went well as I installed the two washers. It was also really good to spend an hour or so under the car (first time ever) to take a look at things. All looked good with very little moisture anywhere. Pretty good for sixteen years I think.
RESULTS: I should have done this way earlier. A significant lessening of the "notchy-ness" of my shortened stock shifter. Did not drive very far but I will this weekend just to enjoy the effort.
I suggest the mod if you have been as lazy as I had been.
Enjoy
Old May 24, 2019 | 07:57 PM
Dave in Pa's Avatar
Dave in Pa
Congratulations on success!! I too have been following "this thread" as a new C5 owner and my try this mod also, glad to here you like the results!! Dave
Old May 25, 2019 | 07:25 PM
run1fsr's Avatar
run1fsr
Need to do the same. Did you put the car on a lift or use a floor jack / jack stands?
Old May 25, 2019 | 08:41 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
As the saying goes... better late than never Allegro! Glad it went well for you... enjoy!
Old May 25, 2019 | 10:52 PM
ALLEGRO's Avatar
ALLEGRO
I luckily have a neighbor with a lift in his workshop/garage. Made for easy access considering you are doing all the ratchet work blindly yet needing a good deal of torque to loosen and then reinstall the nut.
I think it can be done on blocks but it would be much easier on a lift.
Old May 26, 2019 | 08:50 AM
Good mod to help make the car more enjoyable to drive. Better late than never.
Old May 26, 2019 | 10:31 PM
ALLEGRO's Avatar
ALLEGRO
You are so correct Vetteman. It has made a world of difference. Still very positive ingaugement but with far less effort. I should have completed this mod 16 years ago.
Old May 28, 2019 | 06:17 AM
ZigZag's Avatar
ZigZag
Would it really do anything for a 20 year old stock shifter ?
Old May 28, 2019 | 10:50 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Worked decently for me, but changing to Amsoil actually made more of a difference.
To This Forum Did It Again
