C5 on Extended Drives
Old Jun 6, 2019 | 04:51 PM
UM Rebel's Avatar
UM Rebel
Originally Posted by UM Rebel
If your car is stock or near stock you will have no problems with overheating. 2004 CE Ragtop 110k miles has never overheated.
I've got to admit. One time it did give me a scare. Half way home from an 800 mi round trip temperature guage pegged high. Check guages light came on. DIC read coolant temp as XXX. I pulled over opened hood and could see or hear no indication engine was hot. Oil pressure and Oil temperature was normal. I drove the rest of the way home with some apprehension but no problem. Next morning with engine stone cold temp still showed pegged high. I unplugged the temp sensor connection. Sprayed on some circuit cleaner. Coated connector with dielectric grease.Problem solved.
