Water pump
Old Jun 10, 2019 | 02:58 PM
tcallebaut1's Avatar
tcallebaut1
Cruising
Default Water pump
Installed a new water pump on my c5 fit great except the belt has to be smaller now. Would you please tell me what I did wrong. 2003 c5 fastback.
Old Jun 10, 2019 | 04:43 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
How are we supposed to know what’s wrong with such a vague list of details?
Perhaps list the part number of the pump you bought, maybe a picture too. Maybe you routed the belt wrong.
Old Jun 10, 2019 | 05:38 PM
tcallebaut1
Cruising
Default Water pump
Thanks Josh. Put in new pump last year everything ok but I had to use smaller belt. Checked the bell on the pump it was same size as old one. Had to use Smaller belt but everything is ok. Routed belt per specs. Last week had a power steering leak. The belt was hitting the steel rack and pinion line under the power stearing wheel It wore a hole in it. Don't have old pump to compare with new that is already in. Can someone give advice.
Old Jun 10, 2019 | 05:46 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Might want to take a peek at your harmonic balancer....mind started wandering towards the rack as well...
Old Jun 10, 2019 | 05:49 PM
3sACROWD's Avatar
3sACROWD
As stated, you likely misrouted the belt. A picture may help.
Old Jun 10, 2019 | 06:09 PM
tcallebaut1
Cruising
Default Water pump
No movement in balancer as far as I can tell.
Old Jun 10, 2019 | 06:11 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Unless it's a complete failure, it's tough to tell that it's going away.
Old Jun 10, 2019 | 06:18 PM
tcallebaut1
Cruising
Default Water pump
Thats what I thought. Since I had to put on a smaller belt when installing the pump lm going to pull it an recheck size with new one. Belt size changed by 2 inches. Checked belt diagram alot.
I like to thank everyone for the good good advice
Old Jun 10, 2019 | 07:33 PM
StingrayRebel's Avatar
StingrayRebel
a size down I would think maybe the new pulley was slightly larger than the stock one but a 2 inch difference is too much, check the belt routing and make sure your tensioner mark is about in the center of it's travel with the belt installed... is the rest of your pulley setup stock?... just want to make sure you don't have a supercharger or something that would make a big difference in belt length/routing
Old Jun 10, 2019 | 08:17 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I don't care what you change you can't change the belt by 2 in. You've got to have it routed wrong.
Old Jun 11, 2019 | 08:03 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Unless he got the wrong water pump, one with a significantly smaller pulley.
And once again a poster comes in with a rather vague question, is asked for more details, especially a picture, in order for us to provide a better answer, but ignores the requests, and just insists on re-phrasing the same question over and over....
Old Jun 11, 2019 | 08:56 AM
K-Spaz's Avatar
K-Spaz
Yup...
My water pump works just great. Belt looks great too.
Old Jun 11, 2019 | 11:38 AM
vettin_it's Avatar
vettin_it
Belt rubbing on steering lines and 2" shorter has me thinking the belt is going from power steering crank and skipping number 8 in this diagram. Maybe that idler pulley wasn't put back on when the pump was done.
Old Jun 11, 2019 | 12:10 PM
mykream's Avatar
mykream
Exactly what I was thinking.
To Water pump
