Failed inspection!
Old Jun 20, 2019 | 10:46 AM
Robrote's Avatar
Robrote
Default Failed inspection!
I had my appointment already made to have the windows tinted on the car. I figured, I better get it inspected before the tint goes on. I took it over last night and the DE DMV was not impressed with my new side marker lenses. The rules say, they have to have a amber lens. I argued my case with them explaining the modern technology of the switchback LED bulbs, but they were less than impressed by those. So, this weekend I will be pulling the new ones out, putting the old ones in and running it through on Monday morning. If you read this post backwards, that's what I'll be doing Monday afternoon.
Cheers
Old Jun 20, 2019 | 10:54 AM
ArtClassShank's Avatar
ArtClassShank
Looks like you got unlucky with the inspector. Pretty sure Maryland has the same rule, but I have no lenses, just an amber bulb. Passed!
Old Jun 20, 2019 | 10:59 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
You can buy orange translucent wrap on ebay/Amazon. Put that on top of the covers for the purpose of the inspection, then pull them off after.
Examples:
https://www.ebay.com/sch/i.html?_fro...Desc=0&_sop=15
Old Jun 20, 2019 | 11:02 AM
Robrote's Avatar
Robrote
Examples:
Not a bad idea
Old Jun 20, 2019 | 02:03 PM
FYRARMS's Avatar
FYRARMS
Not every car comes from the factory with amber lenses. Does the state use some kind of guide that tells them which cars should have OEM amber lenses? Either way, that is stupid!
Old Jun 20, 2019 | 02:09 PM
Robrote's Avatar
Robrote
Here is the law. I can guarantee that there are unmodified cars that do not fit this criteria
Reflectors - All vehicles manufactured after 1953 must have at least two red reflectors on the rear, either separate or as part of taillight assembly (Motorcycles need only one). All passenger cars made after January 1, 1970 must have front and rear side marker lights as well as reflectors per Federal Motor Vehicle Safety Standards (FMVSS). 2 amber reflectors and marker lights, one on each side as far to the front as practicable at least 15 inches from the ground and no more than 60 inches from the ground. 2 red reflectors and marker lights, one on each side as far to the rear as practicable at least 15 inches from the ground and no more than 60 inches from the ground. All reflectors and marker lights must be a minimum of 4 square inches.
Old Jun 20, 2019 | 04:35 PM
Car Rookie's Avatar
Car Rookie
under that law you posted, I don' think you will make the height requirement either. I just measured mine and they are 15" to the top of the light and if I raised it back up it would 15" to the middle of the light at best. And I am only lowered on stock bolts. The way I would read that law is they would have to be 15" to the bottom of the light because how it's worded " 2 amber reflectors and marker lights, one on each side as far to the front as practicable at least 15 inches from the ground and no more than 60 inches from the ground". Not trying to open a can of worms just making an observation. Washington state just quit doing emissions testing for the areas that needed them and I was not in one of those areas anyway.
Old Jun 20, 2019 | 04:50 PM
Jim_ZO6's Avatar
Jim_ZO6
2020 Corvette of the Year Finalist (stock)
C5 of Year Winner (stock) 2019
Stupid Nanny State BS.
Old Jun 20, 2019 | 04:53 PM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
Examples:
This is exactly what I was going to post. Screw pulling them out...they have amber materials to easily apply to the lense...hairdryer and a couple minutes...easy. I used to yellow headlights for people all the time that liked the older GTD/GT3 yellow headlight look.
Old Jun 20, 2019 | 07:15 PM
vetteLT193's Avatar
vetteLT193
Every car in America has amber reflectors on the front corners. Your new lenses changed that reflector to clear. All it needs is the amber over the side reflector and you are set.
Almost every car has some sort of kit to cover the reflector because they are ugly on many cars. My BMW has them where a euro spec on wouldn't.
To Failed inspection!
