Racing oil
Old Jul 10, 2019 | 01:29 PM
mytherapy's Avatar
mytherapy
Default Racing oil
I was curious what oil you roadcourse guys are using on the track?Ive been using Amsoil 5w-30 for street driving and Autox,but im not sure if it can hold up to roadcourse work.Im in a stock C5Z with Dewitts Pro Series radiator,and i run Hoosier R7’s.More cooling mods coming soon as well.Thanx for any input!
Old Jul 10, 2019 | 03:39 PM
gimp's Avatar
gimp
What temperatures and pressures are you seeing?
Old Jul 10, 2019 | 03:58 PM
fuggles's Avatar
fuggles
On stock cooling I was seeing high oil temps at the track. 295F+. So I started using Amsoil 10W-40. Now that I have a Ron Davis radiator with EOC the temps have come down dramatically so I am switching back to 30W oil. The 40W oil increases oil pressure by about 10 psi. Which concerns me a bit.
Old Jul 10, 2019 | 04:02 PM
petdsim's Avatar
petdsim
Valvoline vr1
Old Jul 10, 2019 | 04:34 PM
Budwise's Avatar
Budwise
I would do Amsoil Dominator 15w-50.
Old Jul 10, 2019 | 05:27 PM
mytherapy's Avatar
mytherapy
260coolany and 300oil before the radiator swap.
oil pressure was 50 i think.28-30psi at idle just after coming off track
Old Jul 10, 2019 | 05:34 PM
gimp's Avatar
gimp
If you're maintaining pressure at that temperature, increasing weight is probably not necessary. Going to a different spec oil for a different additive package may be useful. Frankly I'd worry more about oil cooling than oil weight given your generally acceptable pressures.
To Racing oil
