Reset oil life remaining warning?
Old Jul 28, 2019 | 04:17 AM
tigertim20's Avatar
tigertim20
Default Reset oil life remaining warning?
C5 has this warning coming up, but oil has just been changed.
I have held down the reset button when the warning is showing up, and it changes to 'Oil life remaining ___"
but thwne I start the car again, it goes back to 'oil life 5%' warning again.
how do I reset this?
and no, I do not have a manual, it did not come with the car
Old Jul 28, 2019 | 04:42 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Turn the ignition to position On without starting the engine. Scroll through the DIC Info Pages menu until the REMAINING OIL LIFE percentage is displayed. Finally, hold down the “SEL” or “RESET” button until the “Oil Life” display changes to 100 percent.
You can also turn the ignition to "on" don't start it - press and release the gas pedal
four times ... it will reset the %
Old Jul 28, 2019 | 09:47 AM
Phanni's Avatar
Phanni
The quickest way is to turn ignition to "on" without starting engine, then press accelerator to floor three times. It is done.
Old Jul 28, 2019 | 12:17 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
mine does not always reset using the DIC ????
Old Jul 28, 2019 | 06:40 PM
dbgoodwin's Avatar
dbgoodwin
The reset method only works if the engine isn’t running for me. Engine running: never resets.
Old Jul 29, 2019 | 08:39 PM
Do what laurent z06 says and the oil life monitor should reset. It always worked for mine.
To Reset oil life remaining warning?
