Clearing False codes
Old Aug 18, 2019 | 05:19 PM
scopel56's Avatar
scopel56
3rd Gear
Default Clearing False codes
I sent my EBCM (ABS) in for repaired. Repaired and codes cleared. Reinstalled Module and codes 1271 & 1272 appear w/ABS and Traction Control Icons on dash. The 1271 & 1272 reference master cylinder and LF wheel pump. The associated parts referenced by the codes 1271 & 1272 check out and are working well. Can't clear codes and icons on dash via car. Any ideas have to clear these false codes? C5 2000 coupe 5.7
Old Aug 18, 2019 | 05:26 PM
knewblewkorvette's Avatar
knewblewkorvette
If the codes have a "C" behind them you cannot clear the codes via the DIC. You need a Tech II or equivalent.
