Coolant type?
Old Aug 25, 2019 | 11:22 PM
andersonzo6's Avatar
andersonzo6
Default Coolant type?
I was bypassing my throttle body coolant line today and I realized that the coolant coming from the lines was a light green. I went to top off the surge tank and saw that it was orange. Why would there be dexcool in the surge tank but greenish coolant in the radiator, hoses, and block? Thanks, I want to make sure what to do.
Old Aug 26, 2019 | 12:01 AM
USAZR1's Avatar
USAZR1
Dexcool does not play well, with other coolants. If it were my car, I would do an immediate flush of the entire cooling system.
Old Aug 26, 2019 | 12:12 AM
andersonzo6
Thanks, I'll plan on it. What I am confused about is that I have had the car like this for almost 4 years now and it has never been a problem car stays under 200 all the time. The coolant is super clean and no junk. Well I guess the 5 years is already up so I'll go ahead and change it out.
Old Aug 26, 2019 | 12:19 AM
El original's Avatar
El original
Absolute must, Dex cool and distilled water. I am surprised you have not experienced any corrosion....lets just hope and pray. You will find out when flushing old coolant. Heard some real horror stories on this topic. Good luck. PS that is a real mystery, why dex in reservoir and green in other location...weird. Let us know when you find out more.
Old Aug 26, 2019 | 12:21 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Old Aug 26, 2019 | 10:23 AM
JR-01's Avatar
JR-01
Peak Global Lifetime..... better than Dexcool in every way.
Old Aug 26, 2019 | 11:38 PM
This. Do the flush and ensure that the right coolant is put back in.
Old Aug 27, 2019 | 12:22 AM
az57chevy's Avatar
az57chevy
Might be sludge in the overflow and not orange anti-freeze?
Old Aug 28, 2019 | 04:06 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Most people don't understand the need for the proper coolant. Even GM get's it wrong sometimes. 68 GTOs came with a aluminum timing chain cover and their factory coolant ate through the passage between the oil and coolant & you got a nice mix of coolant in your oil. Now that I think of it it's time to flush the system and replace with new coolant. Time just goes by so fast it's easy to get behind on these things.
Old Aug 28, 2019 | 04:33 PM
jcgunn's Avatar
jcgunn
Do a thorough flush. The Dexcool and "Green" coolant can congeal and create a jelly like stuff.
Old Aug 30, 2019 | 09:44 AM
jjc508520's Avatar
jjc508520
Sounds too good to be true!
https://peakauto.com/products/antifr...full-strength/
Old Sep 4, 2019 | 07:41 AM
Not4spd's Avatar
Not4spd
Extended life coolant that is unvirsal comes in a green tint as well. Most likely that is what is in there if it hasn't been an issue. Years ago when I worked as a lube tech that is what we would top off with. I actually just recently had to add coolant since it was low. Picked up some long life universal coolant from autozone and it was a green tint.
To Coolant type?
