I noticed my front plastic air dam underneath the car is in really bad shape. How important is it and can I just take it off? One too many parking blocks!
Anyone know where to get one for a reasonable price. Amazon and eBay are quite expensive unless you are buying a C6 or C7 Model replacement. Found a really cool one for $160, under C5 search engine, only to find out its for a C6....🤬🤬🤬🤬🤬.
I've got a reproduction set on mine. Kind of falls under the one or two engineering axioms that actually work for me: good enough is. Not great, but good enough. Worth $100ish. Keeps my temperatures where they have always been.
You need to stop pulling so far into parking spaces. The Vette is a short car and won't stick out of the parking space if you don't over hang the parking block. If you have a HUD, it appears about where the front of the car is. You can use it to judge distance.
Lastly, the center air dam directs air to the AC condenser and radiator. The end pieces direct air around the tires for aerodynamics.
