break squeak
Old Sep 19, 2019 | 07:43 PM
lunaticfringe007's Avatar
lunaticfringe007
Default break squeak
I had a break/brake squeak on the left rear of my 2001 vert. Right behind my ear. Annoying as hell and showed up out of the blue. So I don't know the history of the car and decide to replace all of the shoes with Raybestos Metallic pads. The rotors look stock and are smooth with no pulsing when I am heavy or light on the breaks/brakes. I did not have them turned. The old shoes were at about 50% worn and did not have any of that break/brake quiet stuff on the back of the pads. So I pull out the old ones and put the new ones in with the pink break/brake quiet stuff on the back of the pads. Now the left rear squeaks worse than before. I wonder if it will go away as they wear in? Or is there some other stuff I can put on the pads that eliminates the squeak? Any ideas?
Old Sep 19, 2019 | 08:21 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Did you grease the pad tabs.. and clean the tab runners??? brake dust accumulates in the runners, and the pad tabs can act like nails on a chalkboard.. since the tab runners are hardened metal, as are the pad tabs.
Old Sep 19, 2019 | 11:03 PM
lunaticfringe007
Not sure what you are talking about? So i probably didn't
Old Sep 20, 2019 | 08:33 AM
Phanni's Avatar
Phanni
With that said, do your brakes make a noise?
Old Sep 20, 2019 | 09:25 AM
Evil-Twin's Avatar
Evil-Twin
There are two guide tabs on each pad.
They side into a removable retainer in the caliper. The retainer is a hardened piece of hardware. This retainer gets filled with brake dust overtime and can bind the pads. You need brake pad grease. A can of brake clean will clean the retainers. Once clean, add some grease . The pad tabs will float in these guides without binding and there will be no hard metal to metal dry contact in this high contact area
Old Sep 20, 2019 | 03:17 PM
lunaticfringe007
LOL! Yes did I break my brakes? That is the question.
Old Sep 20, 2019 | 08:39 PM
gimp's Avatar
gimp
ET is absolutely right. The slide pins _and_ the retainers on the side, where your brake pad backing plate's tabs ride, needs some grease.
Old Sep 20, 2019 | 09:07 PM
Ryanhogan3232's Avatar
Ryanhogan3232
Cruising
It also depends heavily on what the composition of the pads you bought. And rotors.
Old Sep 20, 2019 | 10:43 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Yuo shude bulrakat hte breaks wuth sum greese.
Old Sep 21, 2019 | 11:44 AM
lunaticfringe007
Ok...ok it was stupid...i get it.
Old Sep 21, 2019 | 01:26 PM
Evil-Twin's Avatar
Evil-Twin
Everyone here is well meaning.. sometimes a little hazing goes on but for the most part most people, especially long time tenured members are here to help... Sometime my dry humor is mistaken for hostility.. Dont tale it to heart , this forum is a good place with good people, you just need to find out who they are.
Old Sep 21, 2019 | 05:05 PM
lunaticfringe007
Well so far so good. Break/brake Greece/grease worked. No more noise.
Old Sep 21, 2019 | 07:25 PM
Evil-Twin's Avatar
Evil-Twin
♫♫ Grease is the time , is the place , is the motion. Grease is the word. Grease is the way we are feeling ♫♫
Old Sep 21, 2019 | 07:28 PM
Evil-Twin's Avatar
Evil-Twin
I'm not just another pretty face. I know stuff
Old Sep 22, 2019 | 08:30 PM
lunaticfringe007
No ****..never doubted it...
Old Sep 22, 2019 | 08:43 PM
Glad you got the squeak or squeak fixed. The forum comes through again.
Old Sep 22, 2019 | 08:51 PM
Evil-Twin's Avatar
Evil-Twin
All pads have some sort of tab or guide.. even shoe brakes need grease at certain contact point on the backing plate...
To break squeak
