Remote High Speed Fan Controller
Old Sep 23, 2019 | 11:51 AM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Remote High Speed Fan Controller
I came across this product while looking for solutions to some additional cooling since I installed a front splitter. In theory it seems like a great idea, and your system still retains your factory fan settings as well. I haven't had enough opportunity to test it in practice yet, but it sure can't hurt.
https://www.saccitycorvette.com/COOLITv2.html
Old Sep 23, 2019 | 12:03 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
This has been around for a C5 for about 15 years. The original is called a Da Vinci fan controller. You have to be very careful with a fan controller. Since the OEM fans are designed to cycle on and off.. With a CE certification of 180,000 cycles. If you over ride the system and allow the fans to run without cycle control, you will burn up the fans..
These controllers are designed to work with a lower thermostat with a radiator probe. You DO NOT want to Have the fans running all the time.
Just a heads up
Bill
Old Sep 24, 2019 | 04:52 PM
Chris Draper
I've been known to get something wrong every now and again. It's all a leaning process. I'm glad we have this community to learn from each other.
Last edited by Vetteman Jack; Sep 24, 2019 at 05:45 PM. Reason: Removed quote of deleted post.
Old Jan 7, 2025 | 11:36 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
Its actually harder on the fan motors to be cycling on/of constantly like when you are in traffic, then to have them come on and just run for a while.
That way it doesn't use up as much of the the 180,000 Cycles. Its a lot of strain on the fan motors getting those fans up to speed.
Thank you,
Christian
SacCityCorvette.com
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jan 8, 2025 | 08:43 PM
Ajl#1945's Avatar
Ajl#1945
St. Jude Donor '22
Been using the cool it 2 for years works great on those hot, stuck in traffic days
Old Jan 9, 2025 | 11:08 PM
ncali's Avatar
ncali
I have used mine in two corvettes and it works great. when I notice the car getting hot I use it. most of the time it is not needed
To Remote High Speed Fan Controller
