2003 Convertible, trunk CD changer
Old Sep 23, 2019 | 07:34 PM
BayVette's Avatar
BayVette
Default 2003 Convertible, trunk CD changer
After I was away most of the Summer, when I tried to play a CD in the trunk mounted 12 dic player I got 'Err' on the radio dial When I slid its door to the right I could hear discs being moved around, but the cartridge would not eject. The player worked fine just before I left in June. Any advice?
Thx in advance
Jerry
Old Sep 23, 2019 | 08:38 PM
BayVette's Avatar
BayVette
Default 2003 Corvette, sorry!
Senior moment!
Jerry
Old Sep 23, 2019 | 09:05 PM
GCG's Avatar
GCG
If resetting it with a pin through the little hole on its faceplate doesn't do the trick of bringing it back to normal behavior, try this to remove the stuck magazine:
Remove the changer from your car and open its cover. You will see that it is basically divided in 2 areas placed side-by-side, one to accommodate the magazine and another one where the selected disc gets extracted to and played.
Below the area that holds the loaded magazine, approximately centered with respect to it and opposite the loading door, there is a white plastic lever. If you action that lever, it will unlock the magazine. Just be careful because one of the trays or CDs might be stuck half way between the magazine and the playing area, preventing you from freely pulling the magazine. Be gentle!
Old Sep 23, 2019 | 09:41 PM
BayVette's Avatar
BayVette
Thx GCG! My 70 year old hands/fingers aren't up top that (I think), but I'll give it a try!
Jerry
Old Sep 23, 2019 | 09:50 PM
GCG's Avatar
GCG
You're welcome! Let me know how it goes
Old Sep 24, 2019 | 12:13 AM
Corrected the model year in the thread title.
Old Sep 26, 2019 | 05:35 PM
BayVette's Avatar
BayVette
GCG
I removed the changer from the trunk and removed the 4 screws on the sides. How do I get the cover loose?
thx
Jerry
Old Sep 26, 2019 | 06:05 PM
BayVette's Avatar
BayVette
CGC,
I removed the 2 connector screws and got the cover off. Can't seem to find the white lever you referred to. I can send you a photo if you can share your email address. Mine is belair1956@comcast.net.
thx
Jerry
Old Sep 26, 2019 | 06:45 PM
BayVette's Avatar
BayVette
CGC,
Old Sep 26, 2019 | 09:16 PM
GCG's Avatar
GCG
Jerry, sorry for not getting back to you sooner. I can imagine how you feel, stuck in the middle of the repair process.
Since a picture is worth a thousand words, I have a few pics here to help you. I just took them and added some annotations.
You already removed the top cover. Now you need to do the same to the bottom one. Just be gentle. There are no more screws to remove. Bottom view, from behind:
Once you unlock the magazine, be careful because it's possible a tray or a disc may be stuck halfway between the 2 areas.
Good luck and let me know how it goes!
Gilbert
Old Sep 26, 2019 | 09:32 PM
BayVette's Avatar
BayVette
That clears it up! So, the guts lift out of the lower case, gently persuaded? Your photos with annotations are a huge help. Were you a techie once (or now)? We are of to dinner in Beserkely, a fine wine is called for! Slainte'!
I'll be back at this first thing tomorrow. Here's my other toy, 1956 Bel Air Sport Coupe, 100% stock.
Take care
Jerry
Old Sep 27, 2019 | 12:16 PM
BayVette's Avatar
BayVette
GCG,
I removed the guts from the lower case and the face plate. I pushed the lever and heard the release click. I'm not sure how to persuade magazine to eject. There is a disc in the play side, but I don't think it's restricting the magazine. I'll keep trying but welcome your sage advice!
Thx
Jerry
Old Sep 27, 2019 | 01:10 PM
BayVette's Avatar
BayVette
GCG!
I plugged the unit into the harness, opened the access door out popped the magazine! A disc (in its holder) was halfway into the play are. I nudged it out. No idea why it got stuck in the first place. Then I found a disc stuck in the play area and was able to remove it. My Vette did spend the Summer in my garage, there were 2 heat waves; perhaps heat caused an issue? All back together again. Any cleaning I can do?
Thx again
Jerry
Old Sep 27, 2019 | 02:32 PM
GCG's Avatar
GCG
Congratulations! Job well done!
That was my suspicion all along. By any chance, while the magazine was inserted in the changer during the summer storage, was the battery perturbed at any point? When the changer gets energized, it goes through an initialization process that includes scanning all the magazine trays. If power was interrupted again while it was going through this, it's possible that a tray was caught midway between the magazine and the playing area, and then when power was restored the mechanism was not able to recover from that.
I suggest when you're planning to store the car for a while, to remove the magazine from the changer as a preventive measure
By the way, your '56 is beautiful!!!
NOTE: regarding maintenance, to take advantage that it's completely open, you could try to clean the laser's lens with 91% isopropyl alcohol and a cotton swab. Just be gentle and don't leave fibers behind
Old Sep 27, 2019 | 07:04 PM
BayVette's Avatar
BayVette
GCG!
My 12 CDs of Oldies are alive!! Your guidance was the reason for my success! You are very knowledgeable! The car sat all Summer. When I first started it upon my return the battery was very weak. Next absence I will indeed remove the cartridge.
I had contacted a repair shop in La Jolla CA; they wouldn't touch the changer. 'Too old'. Well, I'm old and I (and YOU) fixed it! I can't thank you enough!!!
Best regards,
Jerry
Old Sep 27, 2019 | 08:11 PM
GCG's Avatar
GCG
Jerry, it was my pleasure to give you a (remote) hand. If anything, you were an outstanding student!
I'm really glad everything is up and running now. I too enjoy my CD changer to the max, so I understand how you must have felt.
You're very welcome, and if by chance you pass by Miami, FL, let me know so we can have a to celebrate
Gilbert
To 2003 Convertible, trunk CD changer
