[Z06] Decrease in MPG after Vararam?
Old Sep 26, 2019 | 05:55 PM
NickZ06_'s Avatar
NickZ06_
Default Decrease in MPG after Vararam?
I have a 2002 C5 Z06 with 35k miles. In the city I would get 15 mpg which already seems low? And I just installed the vararam intake yesterday and now I’m getting 13.9-14 mpg, is this normal? My car is completely stock otherwise. This is not spirited driving either, just city not highway.
Old Sep 26, 2019 | 10:58 PM
NickZ06_'s Avatar
NickZ06_
Bump
Old Sep 27, 2019 | 08:54 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
After installing the Vararam I noticed a big decrease in mileage too. You have to take a look at your fuel trims. I had a check engine light and P0171 and P0174 were coming up. Long term fuel trim was at 25%. It was affecting my gas mileage by around 5 mpg. I used the Trinity to lean it out and gas mileage is now better than before the installation of the Vararam. I think I still need a real tune but I am waiting until I do some more mods.
Old Sep 27, 2019 | 12:08 PM
smitty2919's Avatar
smitty2919
Get it tuned.
Old Sep 27, 2019 | 12:23 PM
fuggles's Avatar
fuggles
If you are getting cooler air into the motor then you will need more fuel to compensate. That is the point isn't it?
Old Sep 27, 2019 | 01:08 PM
C5MSG2004Vert
The air temp is read by the computer so it will adjust fueling based on that and the air flow into the engine. The Vararam somehow screws up the MAFs air flow reading's. So the computer is adjusting for a signal that is not real. It thinks the engine is lean and adds fuel when it does not have to causing the engine to actually run rich. That is why the long term fuel trims get out of wack and the check engine light comes on.
Old Sep 27, 2019 | 02:15 PM
NickZ06_'s Avatar
NickZ06_
How do I check my fuel trims? I’m planning on getting a dyno tune after I get my exhaust maybe by November, would it be ok to wait that long? And would that fix everything
Old Sep 27, 2019 | 02:16 PM
NickZ06_'s Avatar
NickZ06_
How would I fix this?
Old Sep 27, 2019 | 02:30 PM
smitty2919's Avatar
smitty2919
Getting a tune.
Get longtubes and exhaust figured out then tune it once.
Old Sep 27, 2019 | 03:22 PM
C5MSG2004Vert
As long as your check engine light is off the computer will up to a point relearn the fuel trims as you drive and you should be OK. To fix this you either need a handheld tuner or a canned tune that ECS sells for $150. You can read your fuel trims and other engine parameters with a cheap $20 OBD2 Bluetooth code reader and your phone. The long and short term fuel trim s will tell you what's going on with your car. You could have an air leak at one of the couplers that will create the same kind of problem.
Old Sep 27, 2019 | 03:34 PM
NickZ06_'s Avatar
NickZ06_
What if I got a dyno tune. Will the tuner be able to sort it all out ?
Old Sep 27, 2019 | 03:54 PM
C5MSG2004Vert
Piece of cake for a tuner.
To Decrease in MPG after Vararam?
