Shocks/Strut/Spring
Old Oct 15, 2019 | 04:01 PM
mwestc5's Avatar
mwestc5
moncal90
It's a base convertible and confident it's got the base suspension.
Will be getting the C6 Z51's.
Now that I'm going with the C6 Z51, is there really any need to replace the end links?
By using the stock end links am I defeating the purpose of the upgraded sways.?
Old Oct 15, 2019 | 04:40 PM
unlvrebel's Avatar
unlvrebel
Originally Posted by mwestc5
I had considered Alden’s for my CTS Caddie(not a V), but decided to hold off till I figured out the Vette. Too bad you spent a bunch of $ too find out you don’t like it. I think a lot of us have been there done that. What improvements are you expecting from the Bilstein’s ?
For me, I do like the idea of hopefully solving my soft ride with doing only the sways. Found C6 Z51 sways for about $325 & Hotchkiss for around $100 more.
My new question is, is it worth spending the extra $100? The Hotchkiss are substantially thicker then the Z51. But does it really matter & will the ride quality/handling be worth the extra $100?
If these sways give me the ride I’m looking for I’ll do the same on the CTS.
Hoping for ANY kind of movement over rough road. If I hit a pothole or a sharply uneven surface its way to jarring. I've tried multiple settings on the damper and the coils. I've gotten rid of the run flats. I've talked to the folks at Alden. The shocks weren't made for the general perils that this vehicle may encounter on the road. Plain and simple. The jarring is so bad that some parts with plastic fasteners have broken. Just looking to get back to stock, or close to it.
As to the extra $100... FWIW, I just can't imagine a road vehicle would show the difference between the two. If you were tracking it, another story. But that's just my own uninformed opinion.
As to the Aldens... On continuous pavement, GREAT shock. On asphalt/pavement that could be fractured... not the right tool for the job. And GREAT company to deal with.
Old Oct 16, 2019 | 02:56 PM
Gordy M's Avatar
Gordy M
[QUOTE=mwestc5;1600322976]moncal90
By using the stock end links am I defeating the purpose of the upgraded sways.?[/QUOTE
The end links on the base c5 are plastic and are prone to break with miles and use. The C5Z end links on o4 were metal and will hold up much better
