Halogen headlights
Old Sep 29, 2019 | 10:46 AM
Bills01vett's Avatar
Bills01vett
Default Halogen headlights
As I said in my last post, I’m horrible at searching forums. When I do, I come up with C3 and C4 cars as well. I need information regarding C5. Will I have issues adding halogen headlights to my car with the flip up headlights?
Old Sep 29, 2019 | 04:39 PM
USAZR1's Avatar
USAZR1
If you're searching the C5 General forum, you shouldn't be seeing C3 & C4 threads/posts.
Old Sep 29, 2019 | 06:34 PM
wydopnthrtl's Avatar
wydopnthrtl
Make sure your in "Sub-Forums: C5 Corvettes, 1997 - 2004" and then at the 1-2o-clock position click on "Search this forum"
I assume your wanting to do just a simple swap of the bulbs to gain some performance. (me too)
Here are some tips:
- The headlight doors are sensitive to voltage. So swapping to something like standard LEDs may cause the doors to not work w/o other modifications (adding resistors)
- Here is a plug-n-play LED from a supporting vendor (I'll be ordering these in the future): https://www.vette-lights.com/collect...-low-beam-leds
Old Sep 30, 2019 | 08:44 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
When you say "adding halogen headlights" you realize that the C5 came with halogens from the factory, right?
As for searching, I almost always have better luck searching using google than the internal CR search.
To Halogen headlights
